Question about Samsung WF337AA Front Load Washer
Where is the debris filter locates on a samsung front loader model # WF206ANSXAA
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
My front loader will not empty fabric soft.
Posted on Sep 16, 2011
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Samsung sw80usp wont drain
On my LG I removed the front panel and there was a drain trap with a filter. I removed and cleaned the filter. Mine started draining again. (assuming you have a front loader not a top loader)
May 07, 2014 | Samsung Washing Machines
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
Where is the lint filter?
Is this a front-loader? Samsung hides the filter behind the lower panel on the front.
You can view your machine's user manual here (you need your model number):
http://www.samsung.com/me/support/productsupport/download/index.aspx
Apr 30, 2010 | Samsung Washing Machines
Stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Mar 11, 2008 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
574 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
