Tv only gets 2channels on cable 3 and 4 - Televison & Video
  • 66 Answers
Firstly you tune the automatic mode in telivision and solve it
Posted on Apr 10, 2011
How to hook up subwoofer for yamaha RX-496 2channels receiver
You need to connect the subwoofer to your receiver using the speaker wire connections on the rear of the receiver. Take the speaker input from the subwoofer to the A or B speaker terminals on the rear of the AV receiver. Then take the speaker outputs from the sub and connect to the main speaker terminals. Really you need to buy a receiver with a sub out to do it properly. Sell this one and buy another.
Mar 02, 2017 | Yamaha Audio Players & Recorders
Hello, i need a Tedelex remote, tv model is EC21E19G, we only have 2channels SABC 1 and 2. Please help.
Have you considered a universal remote that uses codes for your TV brand? Another option might be a cel-phone app if you have a newer phone with an IR transmitter.
Nov 02, 2016 | Televison & Video
Directions to hook up tv to cable box .
Set tv on tv input and try 3 . If still not working . Go to tv menu and find set to cable and do auto scan . When done try 3 again . be sure cable bos swith on back is set to 3 and not 4. Hope this helps.
Mar 17, 2014 | Element Electronics Televison & Video
Cobra 142 off frequency on all 40 channels by 2channels
unless you have a frequency counter,other than the radios,and a signal generator you should not even attempt to fix it.
Jan 15, 2014 | Radio Communications
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Cannot get the cable to show on this tv
If the TV is connected to a cable box using 1 solid cable (RF ANT) your needs to be on either channel 3 or 4.
If the TV is connected to a cable box using 2 or 3 RCA cables, your TV needs to be on AV 1, 2 or 3.
If the TV is connected directly to the cable, go to MENU set the TV to cable and program channels.
Good luck
N Sabre
Nov 07, 2009 | Quasar SP-3234 TV
TV plays audio while on dvd, but when we switch it back to cable, there is no sound
If sound works with the DVD, it shows your TV is fine, there is just something wrong with the sound signal getting from your cable box to the TV.
There are a few options here. 1) If you are using a single coaxial cable to connect the TV to the cable box, you can either try another one, or try the 3 component cables. 2) If you are using the 3 component cables, you should have more than one input row to the TV... try an adjacent row 3) If that doesn't work for the 3 component cables, try a new set of component cables. 4) Check the sound settings on the cable box itself. Maybe resetting the cable box will get it to go through the initialization sequence to get the sound set up correctly
Oct 31, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv not working with cable box
Insure your TV is set to channel 4. Then go into your TV's menu and make sure it's set to CABLE and not AIR. There is no need to program your tv, as long as it's on channel 4 and set to recieve Cable it will be fine.
Mar 26, 2009 | RCA F27665 27" TV
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
