I have an Electrolux EWF1083 8kg front loading washing machine. I have a coin stuck in a pipe that feeds to the area at the pump door. The coin is very difficult to reach and I can't extract it. Can I remove the bottom cover the washing machine in order to get a better shot at removing the coin. If so what is the correct procedure for removing the bottom plastic cover.
    President:
  • 1,654 Answers
There is actually a procedure that details how to remove coins from your washer.
  • Unplug the machine to reduce your risk of injury while working on it.
  • Remove the front plate from the bottom of the washing machine. Most front-loaders are designed so that their filter systems are located behind the bottom panel, allowing them to be cleaned regularly. On most machines, the plate should pull off or swing open. You may need a screwdriver to unscrew the panel.
  • Pull out the filter, usually located in the lower right corner, and examine it for coins. Coins are more likely to be found in the pump itself but the filter should be checked and rinsed off first.
  • Pull out the pump and open it in accordance with your specific washer's specifications. Each model may function a little differently but the pumps are designed to be removed for cleaning. You will likely need to unclip the wire harness going into the pump and unscrew one or two bolts holding the pump in place.
  • Pull the hose off of the pump and check it for any coin blockages. If it appears to be clogged, carefully insert a straightened wire coat hanger into it to try to dislodge the obstruction.
  • Remove any coins and other debris from the pump before replacing it and reattaching the wire harness.
  • Examine the drain inside the washer to ensure there aren't any coins there either.
  • Let me know how this works for you and if you need more assistance let me know. Thanks
    Posted on Apr 10, 2011
    E35 error code
    chec the drain pump, if there is a coin blockingthe whole
    Nov 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
    My front loader will not spin but runs on every other cycle
    I had the same problem. Check the filter, I have a GE front loader and it is located behind the front panel under the door.
    Removed the baby's socks and haven't had any more issues.
    Jun 23, 2012 | Frigidaire ATF6000ES Front Load Washer
    Not spinning, not draining, water stuck inside
    the pump in the lower area below the drum is plugged with coins,hairpins,etc.,and you need to remove the lower panel in front and open up a round circular cleanout trap that is located by the pump
    Dec 27, 2010 | Whirlpool AWM6140 Front Load Washer
    I start the machine, it runs till it would appear that it is full of water and ready to start to wash, then shuts off, displaying a message saying "Unable to fill - check water supply" IF you then push the...
    disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
    Oct 14, 2010 | Dyson Memory CRO1 Front Load Washer
    I washed by wedding ring and now its gone is there anyway that my husband can take apart the washer and find it?
    There is a catch filter in the large hose going to the drain pump from the tub, it will be in there.
    Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
    The water won't drain out of my HJA8552-HJA8513 washing machine. For a couple of washes before it stopped draining it made a very loud noise...What could be wrong with it?
    There is a possibility that something like a coin has got stuck in the impeller of the drain pump, you may want to check and clean the drain pump, in most of the machines there are coin traps provided look for the same in you machine.
    Feb 25, 2010 | Washing Machines
    My front load washer has the door lock stuck and the door is open
    When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
    Feb 10, 2010 | Electrolux EW1000i Front Load Washer
    Dyson coin compartment problem
    try this push red clip up THEN turn to left the coin trap window,pull pipe firmly off from inside,clean gunk out,replace pipe pointing downreplace door by aligning notches turn to right 1 complete turn,if it feels tight turning TRY AGAIN until it feels smooth to turn.
    Dec 03, 2008 | Dyson Memory CRO1 Front Load Washer
    WHAT DOES OE MEAN. MACHINE NOT EMPTYING AND NOW NOT SPINNING
    Had the same problem and there was a $2 coin stuck in the hose that empties the water from the barrel to the pump. Couldn't find the problem initially, but after numerous times emptying the front drain pump filter (little carriage you pull out) I felt inside where the pipe empties into this carriage and felt the coin. Had to get underneath and pull off the pipe that attaches to get it out. Hope this helps.
    Nov 16, 2007 | LG WM-1480FHD Front Load Washer
    Washing Machines Logo
    118 people viewed this question
    Top Washing Machines Experts
