Question about Sony Playstation 3 (PS3) Console
I have the Avatar bluray disc which is not working. It was working fine until we did an update. The disc is not damaged and all other disc are working.
    Novelist:
    Sniper:
  • 90 Answers
Hi steve,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
Posted on Apr 12, 2011
I have the latest software version for the BDPBX2 11.4.008 when I try to play the Avatar Bluray DVD I get the following message: if you experience problems playing back this DVD go to...
I have Avatar Blu-ray movie and it plays on my BDP-BX2 11.4.006 version. Take it back and get it exchanged. Try new one. May have to go to another store since the same shipments (bulk) that are at your store are ALL the same. I have done this 4 times with 4 different movies and 2 of them worked. I'm getting the .008 update but, I'm starting to think the Blu-ray disc are the problem since I have one that is made in Mexico??? I don't think they are all being made correctly. Too Cheap!
Nov 07, 2010 | Sony BDP-BX2 Blu-Ray Player
Just had a strange problem with PS3 trying to play Clash of the Titans bluray. Started fine, played first two previews/commercials completely, then blank screen and won't react to controller commands. ...
first before it even gets into first preview start hitting the fast forward or next button untill you get to root menu or you can try hitting the green triangle button and try menu button but i had same problem and skipping forward worked for me
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
The new avatar blu.ray dont work
If the firmware update still doesn't work, ensure you have a USB key connected to your player. I have the BDP-S350 and Avatar wouldn't work until I connected a USB drive to it. Ensure it is formatted correctly-anything new should work fine.
May 31, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Element EDBCO11 + Avatar = problem
Avatar bluray disc uses some super-new technique for copy-protection, which many players don't support yet. If you already upgraded to the latest firmware, you can only contact your dealer and ask them - or wait for even newer firmware.
May 12, 2010 | Element Electronics EDBCO11 Blu-Ray Player
Need new update to play avatar.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
May 10, 2010 | Sharp AQUOS Blu-ray Disc Player
I have a Sharp BD-Hp20 and i already got the firmware update and still cannot watch Avatar Bluray please help.
Make sure that you do have Version HU9071500 installed--->press setup button------>settings-------> version. If it is installed then after you insert Avatar it takes between 8 and 10 minutes before you can select play movie.
May 09, 2010 | Sharp AQUOS Blu-ray Disc Player
Blue ray player wont play a new disk says it needs
Software updates have to be done on bluray players whenever the technology in bluray discs themselve is changed. If you call the number for 20th century fox on the back of the bluray a representative there will explain to you what has changed technologically in this bluray that has caused there to be software updates for all of the bluray players. I believe LG can send you a disc so that you can update your player. Give them a call. The bluray players are all manufactured and shipped to the stores. In the meantime if an update is needed and its sitting on the shelf at the store until you buy it, even if you've just bought it an hour ago it will still need to be updated. The stores do not unbox the blu ray players and update them for you. However the Geek squad will update bluray players for customers for a fee.
May 06, 2010 | LG BH100 Blu-Ray Disc Player
Bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Apr 26, 2010 | Sharp BD-HP21U Blu-Ray Player
go to sharpusa.com and put in your model number..download to flash drive and update bluray
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
