Question about Husqvarna Sewing Machines
Huskylock 680cd overlocker have to rethread having trouble with last thread would like a manual or pic showing how to re thread this machine
akylas
  • 26 Answers
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
Posted on May 28, 2008
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Posted on Oct 20, 2008
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
  • 1116 Answers
SOURCE: Huskylock 910
Here is a video - http://www.husqvarnaviking.com/us/421.htm
Posted on Mar 15, 2010
  • 1116 Answers
SOURCE: instructions for threading the huskylock 34d overlock machine
I found this manual - http://www.sewingmachinemanual.net/
However, if you google 'how to thread a serger indi" you will get a video that will give you the basics.
Before you start, raise the antenna to it's highest position and open the tensions by setting to zero, or if your serger has auto tension, raise the presser foot to open the tensions.
Posted on Mar 21, 2010
Threading huskylock 530 serger
Hello
Here is the link for the Huskylock 530:
http://manuals.husqvarnaviking.com/
Enter "huskylock 530" in the empty window and select "Search".
This will bring you to a new page. Click on the blue line containing the descriptions of all overlockers contained in the same manual.
You will be on a new page again where you may choose to download the manual.
Happy overlocking!
Sewingirl/
Jan 31, 2014 | Husqvarna Sewing Machines
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
Huskylock 936 will not form a 4-thread overlock stitch
It may be difficult to solve a computer controlled machine with as many options as the 936 serger. Stepper motors control many of the functions. You can check out this video I made 4 years ago to get an idea of where to look.
Nov 19, 2013 | Husqvarna Huskylock Computerized 936
Need a Husqvarna huskylock 550D overlocker manual
try checking with husqvarna website about a manual or threading diagram
sewingpartsonline.com
sewingmanuals.com
May 07, 2012 | Sewing Machines
My 905 Huskylock was stitching just fine. I changed the thread last night by tying on new threads but one of the knots got caught in the tension plates. I cut it out and rethreaded the machine. It will...
It just may be that you haven't seated the thread in the tention disc, put on hand on each side of the disc when threading and push down to be sure its seated, I don't reccomed that you just 'tye' the treads to change colors, may I suggest that you practice threading your machine, it will come as second nature and really is very easy to thread
Aug 13, 2010 | Husqvarna Huskylock Computerized 905
My overlock is not looping, I have rethreaded 3 times, no loops
You still are not treading it right...don't let it intimidate you, if you follow the manual and make sure that the thread is locked in the the top tension discs you should be fine.
May 04, 2010 | Husqvarna Huskylock Computerized 905
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
Sep 30, 2009 | Sewing Machines
Elna Lock L2 I have overlocker rage..... been threading it as per manual and as per diagram for 3 thread use for the last 3 hours but the threads keep on breaking any suggestions before I throw it against...
Have you made sure the needle thread is the last to be threaded. If this thread is still under the loopers when you rethread, the threads will break .Sewit
Apr 25, 2009 | Sewing Machines
Sewing Machines Logo
95 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
