Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
Tried to upgrade firmware. It accepted everything, I can connect locally through wireless. But the "Internet" status is constantly set on "Disconnected". I have reset the router, modem many times and also reset the modem to factory settings. The most I can do is connect to the router "locally". It's like it doesn't even know the Internet is plugged into it any longer. I think I might be f*cked.
    Visited the website for 60 consecutive days.
  • SMC Master
  • 660 Answers
Did you put the modem in bridge mode?
try plugging computer into to the modem to see if the internet is working
then add router to see if it has internet at the router. try pinging the router and the modem
Posted on Jul 04, 2017
  • 34 Answers
SOURCE: For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem combo?
Did you have DSL prior? if so, was the MAC address cloned to the router? You may need to check that setting, its pretty common with this type of setup
Posted on Jul 29, 2007
  • 16 Answers
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site.
  • 827 Answers
SOURCE: Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Posted on May 23, 2009
  • 6 Answers
SOURCE: Slow Internet
You may need to talk to a professional network and systems tech. There could be a few reasons this could be going. I recommend for help.
Posted on Jun 24, 2009
I have a dir 615. My NookColor ebook reader recognizes my network and connects but says "connected, but no Internet". Sometimes is has Internet for a minute or two and says "connected to...
The first thing that I would try is power-cycling the router to see if that helps at all. This involves unplugging the power cord for about 10 seconds or more and then plugging-in the power cord again.
If this doesn't resolve the problem, then there may be a firmware update for that router. Apparently there are four different revisions of this router on the market, so you will have to determine which revision you have by clicking on the "Support Resources" tab of the router information page.
The directions for figuring out which rev you have are available in the link to the FAQ on that same tab.
Be VERY careful when upgrading the firmware. Most importantly, do not upgrade the firmware over the wireless connection -- hook your computer to the router using an Ethernet cable!
Dec 28, 2010 | D-Link DIR-615 Wireless Router
Not getting the internet through my router anymore
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. elect proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Feb 07, 2010 | Linksys WRT54G2 Wireless Router
Hughes net hn9000 I lose connection when I try accessing Inter.
After upgrading the firmware, reset the router and reconfigure the router.
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless light not on, no wireless signat to computer
Try the following steps:-
1)Connect the computer using an ethernet cable and check the internet connectivity and then go into the router's setting's page and change the wi-fi setting's on the router by changing the channel and security and also enable the wireless router radio from the setting's itself.
2)If it did not work then Upgrade the firmware(drivers) on the router to the latest one available.
3)Even after upgrading the firmware the light status remains the same then restore the router to its default setting's i.e re-set the router and then re-configure it from the beginning.
Nov 27, 2009 | Computers & Internet
Power Light Blinks, can't communicate with Linksys Network Adapte
Seems to be a common issue among these routers. If you tried to upgrade the firmware via wireless connection then it will generally fail. It is recommended to upgrade through the wired connection. In most cases if the upgrade failed and will not reset, most likely the firmware on the router has been damaged. Your best bet is to purchase a new router.
Mar 14, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 connects wired but won't connect wirelessly
I don't think it's a problem with the ip address of the modem or the router since you got internet connection on LAN. I suggest that you try the basic wireless setup without any security etc and see if you can connect. If you can, then maybe it's the WEP setting that is causing the problem. The other problem could be the configuration of the firewall on the computer. You can disable all firewall on the computer and try to connect.
Feb 27, 2009 | Linksys Wireless-G WRT54G Router
firmware reflash:
if the router's SSID is not broadcasted even though it is on "SSID Broadcast enabled" under the wireless settings, you may need to reflash the router's firmware if a HARD RESET did not work.
Hard reset:
this is pressing the reset button on the router for 25 seconds, unplug and replug the power cord while reset is still pushed, then let go of the reset button once the power is plugged back in.
Firmware upgrade:
Click here to get the steps needed to be done.
if this still did not work, you may want to contact Linksys tech support at 1-800-546-5797 for further troubleshooting or an RMA depending on the status of the device.
Aug 18, 2008 | Linksys (WRT54GC) Router
I upgraded my Linksys WRV54G firmware from 2.39.2 to 2.39.2e and completely lost internet connectivity
hi there,
have you tried to reset your wireless router so that the default settings are being used, then try reconfiguring it again for your Internet connection.. then try to connect wireless again ... sounds like your router may have lost its settings which happens for some firmware upgrades.....
Wireless Interferences
Neighboring wireless networks or any appliance that operates on the same frequency as your wireless device (e.g. 2.4 GHz) may cause interference and therefore may affect your wireless connection and signal.
Common sources of interference are:
  • Neighboring wireless networks
  • Microwave ovens
  • 2.4 GHz cordless telephones
  • Bluetooth devices
  • Wireless baby monitors
To solve the problem, change the channel and SSID on your Access Point. Preferred channels to use are 1, 6 and 11 since they’re considered non-overlapping channels.
May 01, 2008 | Computers & Internet
Linksys BEFW11S4 upgrade problem
Download the TFTP---set up file for BEFSR41 v2 and also download the latest firmware of ur router.
Double click on the TFTP file and connect to the router using the default gateway address ( and upload the latest firmware....before that do a hard reset for the router foe one minute.
Feb 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
80 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
