Question about Sylvania G-Netbook
Im having trouble connecting my sylvania windows ce to my desktop router. how do i get it to connect?
    Sergeant:
    Champion:
  • 207 Answers
Does it ask u for a password when required if so enter it if u dont know it ask your provider they will give u step by step instructions..
Posted on Apr 10, 2011
I can not get the laptop to get into internet by pluging into a cable wire for internet, new will not give me any information on isp I have a sylvania ce 7 with ? windows 6?
What about your connection or connectors wire going to router should be cross over. To run for isp is press accessories then command prompt then type ipconfig
Apr 09, 2011 | Computers & Internet
I recently purchased the Sylvania wireless Netbook whose operating system is Windows CE. On our two desktops at home both use Windows 7. My computer downstairs is wired but through the use of a Cisco E...
It is looking for the password that you set your router to or network key.
couple of ways. You can reset your router, then it will default to factory settings and then it will delete your password and open itself up to not needing a password to get on your network. However, anyone can connect to your network, so you will have to enter into your networks menus and reset a password to prevent this, then set that password on all of the computers on the network now. You generally access your set up menu by typing your server IP address into your browser address bar, which is ususlly http://192.168.1.1
This is not all conclusive as some routers have other access methods, but the majority use the above. It will also require a User and a password and the default is usually admin and password or password1 for the default. If however, you have set a password then you definitely have to reset.
Reset is usually a small button , some recessed in a small hole that requires a tooth pick or un-bent paper clip to push into the hole and hold for 15 seconds with the power on the router. Sometimes turning the power off of the router for 2-5 minutes will cause it to reset.
You can also force the laptop(or any client of that server) that you are using and is connected to the internet to give you the english translation of the password. Click on your WiFi icon down in the right corner, A window opens,right click on the name of your network that is connected, click on properties, click on "show charcters." The network key(your password) will be revealed
Jan 31, 2011 | Sylvania G-Netbook
My Sylvania 7" netbook from CVS uses Windows CE.
Google "digital gadgets.com". There find "Sylvania Products". Then click on "7 inch netbook support" and follow directions.
For item # 4, you find your "hot spot" name and click "connect". For item # 5, you may have to call your Internet Service Provider (Charter, AT&T or whoever you pay for your internet in order to get your "network keys" fill that in and then click "OK".
Next be sure you go to "Start", "Settings", "Control Panel", "Internet Options", "General" and complete "user agent (requires browser restart" by selecting:
"Default (same as windows XP)" or
"Same As Pocket PC" or
"Windows CE".
I selected "default" and was off and running.
Although this isn't a "lap-top" it is a really neat little machine and does a lot of stuff almost like one. It should be great for travel! It is a little slow and has small memory, but it's inexpensive and usb/sd ports are there. A regular universal mouse helps-just plug it into a USB port. I'm doing internet, movies, word processing,etc like everything and I think a lot of people are way under-rating this fun machine! -DKA-
Dec 25, 2010 | Sylvania G-Netbook
Want to know if it with get wifi through my cradle point because it has windows ce 6.0 professional plus and cradle point does not show instructions for ce 6.0 only windows 7
If Cradle Point is a router, and it has a WiFi network already in use then the SYNET07526 has a built in WiFi access card that will connect to most any network. One thing, you must set the SYNET07536 up to receive your network which may consist of knowing your router's access code. Read my Tip at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 22, 2010 | Sylvania G-Netbook
I just recently received the sylvania 7 inch netbook as a gift. It comes with windows ce,im not familiar with using this hard wear and for some reason i cant connect to the internet via wifi what can i do?
Windows CE or windows embedded compact is an operating system for minimalistic computers and have minimal storage. My friend had also that notebook but she just browse the features of it and later on she learned how to use it. Windows CE is not a complicated software it's a simple program and easy to learn. Good Day!
Nov 27, 2010 | Sylvania G-Netbook
I have a Sylvania netbook. I could connect to my router and my neighbors unlocked router on my laptop and palm pilot but not the Sylvania netbook. Tech support had me reset it, turn off and on the wifi...
I had a similar problem, and tech support from Sylvania didnt't help. At the end, they told me they would have a higher level tech call me, which of course, never happened. The issue relates to a Windows CE 6.0 problem making contact and receiving an IP address from the router (in my case, I have a DLINK DI-825 router. Since I don't know your router addresses, I will use mine as an example. My router self assigns to 192.168.0.1 as the gateway. You will have to manually assign to get things to work. If you are going to use wireless, make sure to turn on (click wifi power icon, then click power ON. the button will change to power off -- shut the window by clicking ok (do NOT click power off). For ethernet, plug in your cable. Now you must manually assign the IP addresses (this is the windows CE problem.) Click START>NETWORK&Dialup Connections. This brings up a window with icons for each type of connection. The ethernet connection starts with GET, the wireless connection starts with RT. Click the appropriate icon for the connection you are using. You will have to manually assign an IP address on your home network (ask whoever set up your router if there is a problem) I use 192.168.0.99. Click specify and IP address, put in the address you want to manually assign to the netbook, the subnet mask is 255.255.255.0 (universal for home network) and put in you router ip (as I mentioned, 192.168.0.1 in my system). Now click on the name server tab and fill in primary dns ip 4.2.2.2 and secondary 8.8.8.8 (public name servers) Click OK button in upper right corner of window to save settings. Reboot the system. If using wireless, one extra step. Click on the network item in the lower right hand portion of the windows CE taskbar for the wireless connection you want to use. Make sure your password is set up properly and click connect/OK (WEP or WPA or WPA2 all will work.) You should be online. If you take your netbook out, you have to undo the manual IP addresses to log onto public networks, since they often have more complex setups and do not allow you to set up manual (ie static) ip addresses. Hope this helps. Unfortuantely this is a Windows CE issue which is why Macs, Windows XP, Palms, iphones, and linux computers all work without a problem but windows CE doesn't. Good luck and post if this helps you.
Sep 24, 2010 | Sylvania G-Netbook
NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Nov 29, 2007 | NetGear DG834G Router
Sylvania G-Netbook Logo
43 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
