Question about Electrolux Washing Machines
I have an Electrolux washing machine front loader and it is not completing it's complete cycle. I set it on cotton wash which takes just over 2 1/2 hours to complete but when I go back to the laundry to take the washing out it is still sitting in a pool of water so it hasn't rinsed or spun
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
Testimonial: "Thanks for your help we will try this and see how we go."
I have an Electrolux washing machine front loader and the door will not open after the washing has finished
Is the machine completely empty? Doors wont open as they can be hydraulically locked until the water is gone. Check the filter!. Some electrolux machines had a problem with mechanical door locks that wouldn't release - usually the cheaper machines. I used to fit a different style of lock to cure this, but you may only have a replacement of the same type.
Dec 30, 2017 | Electrolux Washing Machines
Tip
Washing machine takes a long time to end cycle.
When a washing machine takes a long time to complete the cycle, that means that one of the conditions required to complete the cycle takes a long time before being met or detected.
In simple words this means that, depending on what part of the cycle the machine hesitates, you are in one of the following conditions:
1 The water inlet is blocked or restricted.
2 There is a water heating problem, usually thermostat not detecting temperature correctly.
3 There is a drain blockage and drain takes longer than usual.
4 The pressure switch used to detect water level is defective, and timer board does not detect that drain is complete and keeps draining for a while.
1 If possible move the machine and check the inlet hose at the back, ensure that there is pressure, that the hose is not restricted or blocked. Check also for blockage at inlet valve.
2 This must be tested removing parts from washer and using a multimeter. The job is better done by a technician.
3 You can check the drain pump. On most front loader models this is accessible opening a panel at the front lower side of the washer, under the door. On top loads the pump is accessed from behind (also some top loader), and from underneath the washer. Instructions are often described in the manual. The hose or filter housing can be removed to check for blockage.
4 Same as 2, the pressure switch is replaced when there is long drain or water level related problems.
Disconnect power before performing any maintainance.
As first step check warranty status by contacting the manufacturer at the number listed on manual. Long cycle is a fault condition, if your warranty is still valid, manufacturer will send an authorized technician at their expenses.
Here a practical description of the problem. Article is referring to a Maytag Neptune: washing machine takes an unusually long time to complete
on Sep 15, 2010 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Washing cycle on a 40degree op. takes more than
    Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
    If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
    If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
    Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
    Kenmore heavy duty 2 way tumble washing machine
    You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
    If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
    In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
    Jan 16, 2009 | Kenmore 44102 Front Load Washer
    A mold smell from my washing machine
    IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
    1. Remove all items from the washer.
    2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
    3. Close the washer door and dispenser drawer.
    4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
    5. Press Start and allow cycle to complete.
    6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
    7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
    8. Repeat the cleaning procedure monthly.
    To maintain the washer freshness:
    1. Use only HE High Efficiency detergent.
    2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
    3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
    4. Use the correct amount of fabric softener.
    5. If your laundry room is damp, use a dehumidifier.
    6. Clean the door seal of visible residue.
    Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
    Odor
    Dec 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    Washer keeps beeping
    HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
    Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    424 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
