Question about Kodak ESP5250 All-In-One InkJet Printer
I tried to insert my memory card from my camera and it will not go in. Are there certain cards it will not take?
    Sergeant:
    Champion:
  • 207 Answers
Yes what kind of camera u have if u have a usb plug in the front you can buy an adapter for your camera at staples or your local electronics store..
Posted on Apr 10, 2011
    Sergeant:
    Champion:
  • 209 Answers
This is from the Kodak website. Hope it helps. Memory card sizes supported by all-in-one printer; maximum file size Published 08/25/2010 11:38 AM ' Updated 03/16/2011 05:44 PM ' Answer ID 1680 What size memory cards can I use in my all-in-one printer, and is there a maximum file size? You can use:
Printer Model Maximum Size Memory Card Maximum Image File Size 5100
5300
5500
ESP 3
ESP 5 2 GB (SD)* 3.6 MB compressed
* For the printer models listed above, if your memory card is larger than 2 GB, upload the files to your computer to print pictures or documents with your all-in-one printer.
Printer Model Maximum Size Memory Card Maximum Image File Size ESP 7
ESP 9
ESP 3250
ESP 5250
ESP C110 / C310 / C315
ESP Office 2150 / 2170
32 GB (SDHD) Unlimited**
** If your image is larger than 3.6 MB, print speed will be reduced and image quality may be affected.
NOTE: For all printer models, a maximum of 1000 JPEG files can be viewed or printed at the printer control panel.
2 Suggested Answers
  • 492 Answers
SOURCE: I insert my camera memory
I plug my camera into the computer and copy the pictures onto my hard drive and flash drives. Then I can use whatever program I like to edit, download, print ect. I have found that photo printers are pretty finicky.
Posted on Mar 19, 2011
Format memory images
Paul,
You are using misleading words. You can format a memory card. And images can have a certain format, So I wonder what you mean.
Your camera can use the following format to save images:
5M (2592x1944pixels 4:3), 3M (2048x1536pixels 4:3),
2M (1920x1080pixels 16:9 )
VGA (640x480pixels 4:3)
To switch to another image format, press the Menu / OK button
Press the up down button till you see resolution then again press Menu / OK
with the up / down goto the format you want and press OK to confirm the selection.
The manual does not say anything about formatting the memory card. If you want to format a new memory card, put it in an external memory card reader and conner it to the computer. Format with FAT32. But my guess is, when you insert a memory card in the camera, it will show CD card inserted. that is the moment the camera will format the camera.
Success
Jan 26, 2014 | Vivitar ViviCam 5024 Digital Camera
Hi.....i am havimng a problem with my memory card PNY Optima SDHC 8 gb class 4......i have been using it in my sony camera....its was working fine at the start but recently after when i inserted the...
You will most likely find that your camera will work with cards up to a certain capacity e.g. 2gb
and not with cards of higher capacity. What this means in effect is that high capacity cards are not compatible with your camera. It would be interesting to know the make and model of your camera.
May 20, 2011 | Cameras
It says memory card error.i took out the sd card and it was not locked and it still says memory card locked. i formated the card also and it still says the same thing.
How big is its capacity ? Some device can only support memory card at certain maximum capacity, if you inserted card with higher capacity it wouldn't able to read it and it would say "card error".
Try to insert another card with lower capacity. i.e. if you have got "card error" notification for inserting 4 Gb memory card, try to insert 2 Gb card
Hope this help, and if you think its helpful RATE please.
Jan 28, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
No Memory Card
Double check the position of the memory card's write protect tab - it should be slid away from arrow pointing at the lock position. If this is OK and the camera is brand new and can be easily returned to the place of purchase, do that and ask for them to correct the problem or replace the camera/card. If returning the camera is not an option, try cleaning the contacts on the memory card itself- a pencil eraser works well for this purpose. Be certain to clean any eraser crumbs from the memory card before inserting it back into the camera.
Sep 25, 2009 | Cameras
Same problem when i inserted my memory stick duo, format error!!! f#@$#$ck
not all memory card are functional to a certain camera. some cameras can't read memory cards that have big capacity. try to format your card through your pc and retry to insert it to your camera again if it works. If it dosn't work then it's not compatible. you have to change it.
Sep 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
System Error 01881-00042
With a new memory card the camera is working properly again. NO MORE PROBLEM
It is very strange, however with 4Euro, the camera is working again.
So if you have the same problem try a new memory card and good luck.
Sep 07, 2008 | Cameras
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Kodak ESP5250 All-In-One InkJet Printer Logo
218 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
