Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
I started up the barbecue for the first time to get all of the winter crud off, and when I start it only the outside burners will flame, the middle one asks like its starting but then burns out?
    Brigadier General:
  • 4,736 Answers
Probably some of the winter crud has clogged the burner and or the venturi valve. Remove the burner, clean it and check the venturi valve for spider build-up. Wouldn't hurt to check the burner orifice too.
Posted on Apr 10, 2011
Testimonial: "thanks for the help!"
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
I HAVE A 10 GALLON ATWOOD WATER HEATER IN A PARK HOME THE PILOT LIHTS FINE AND STARTS THE GAS OK WATER IS NOT GETTING HOT IT LOOKS LIKE SOME OF THE FLAME IS COMING OUT OF THE HEAT TUBE GETTING CARBON ON...
I would definitely have the burner tube cleaned and adjusted if necessary. Sounds like a possible spider web in the tube, as well as have heat chamber blown out with compressed air if at all possible to remove soot build up. Stand back when blowing it out, or you"ll be covered in soot.
You can buy a long brush for cleaning barbecue burners, that work well.
Feb 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
Middle burner of 3 is just a large flame.
Either the burner or the line to burner could be sooted or dirty
Apr 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
No gas flow from barbecue
If you used a power washer you may have driven rubbish into inlets for the burners, or as my collegue has already pointed out, water.
If the BB is empty then turn it upside down onto some newspaper and see if you get a water discharge..
The gas is normally supplied through a hole into the burners and is mixed with air on the way in so that it combusts out of the holes on the burner
If none of them are lighting I would do the upside down bit first , if that does not fix it then start looking at the gas inlets
Jun 19, 2009 | Char-Broil CharBroil Master Flame Gas...
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
GRILLPRO 45,000 BTU, HARDLY WILL RUN, NOT A LOT OF FLAME
The gas burner needs to be scrubed to open the holes again. The transfer bar that lights the outside burners needs to be cleaned also. Make sure the tank is not cold and there is plenty of gas. Make sure the valve is all the way open on the tank. Its not a regulator problem if one of the burner lights and the others don't. Usually if you barbacue a lot the sauce drips down an creats crud on the burners. Just use a wire brush on the burners. You may have to take them out to scrub them good.
Apr 30, 2009 | Brinkmann 810-2300-B Grill
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
163 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
