Question about Hilti Drills
Looking to replace power cord on a hilti TE 6 S hammer drill
  • 2,176 Answers
You can go to any repair shop and match the cord with a suitable replacement. There is a screw holding the back cover where the cord enters the tool. Hilti uses ferrules to crimp on the cord end for better contact if not you can solder them and after installation give them a slight pull to make sure tightened sufficiently.
Posted on Apr 16, 2011
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti te 22 no power
Most common for the TE22 was the switch and or cord. To get to handle off take a 5mm allen wrench and take the two screws off the bottem of the handle and then stick the wrench in through the hole in the top of the handle and remove the screw on the inside. Then take the two phillip screws off the side of the handle to seperate the two halves. You will need to take a continuity tester and read each cord from the plug to the switch. If that reads out continue to read the contacts on the switch. The cord you can replace but if the switch is bad there is not a replacment for it.
Hope this helps.
Nov 24, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I need swich hilti te72 power swich
The only place to get what your looking for is through Hilti, there are autherized dealers almost everywhere. Most times its cheaper to have them fix it for you.
Mar 05, 2011 | Hilti TE 70 Hammer Drill Performance...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
My hilti te 6-s stopped working trigger looks to be ok. wondering how to test trigger and motor to be sure niether is the issue. thnx
I would first check the cord to the switch and then the 2 wires coming from the motor to the switch to see if they have continuity. UNPLUG tool first. to be on the safe side remove the bottom cover 2 T15 Torx screws and look at the brushes also and while apart if you have compressed air blow thru all the openings. The switch is hard to check so I would check everything around it first and if OK I would say a bad switch.
Apr 07, 2009 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Drills Logo
225 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
