Question about Western Digital Computers & Internet
I have the Western Digital fire wire 500GB. Once it's plugged in it shuts off after about 7 seconds. I see a light flicker inside and it goes out too.
    President:
  • 1,285 Answers
All external HD need power to run. is this running on AC, USB or Firewire........ if USB or Firewire is your computer compatible with the HD power needs if it is compatible
and if this is straight out the box, return it is defective........
Posted on Apr 10, 2011
My western digital 500gb hard disk light is not on. It was working so fine. I'm not able to understand the problem
hi
i have the same unit ..eventually if the unit is not unplugged and plugged in in sequence as i describe here, the power module will be expended.
when disconnecting , you have to unplug AFTER you (via software, S/W) disconnect from the ICON found at the bottom right corner of the computer screen , After disconnecting via s/w, unplug the USB cable, then the power cord.
when reconnecting, plug in the power cord, wait 30 seconds, then plug the USB cable in .
this should alleviate the issue at hand. if the unit does not function, then the power module inside the hard disk drive housing is no longer working
i hope this helps
send me 4 thumbs up please.
Aug 17, 2011 | Western Digital 500GB My Book World...
Harddrive not working. When it's plugged in it shuts down after a few seconds. I see a light flicker inside but it isn't sustained.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 10, 2011 | Western Digital My Book Essential 500GB...
Windows xp crashes when western digital hard drive is plugged in
i wish i knew the answer, i am having the same problem. i have switched ALL of my toshiba computer power settings to no stand-by, no hibernation, no automatic shut down (as this was suggested) and windows xp still turns into a blank screen just a few seconds after plugging this in. hard drive too strong for my 3.5 year old computer? not sure, but this is beyond ridiculous.
Jun 15, 2010 | Western Digital My Passport Essential...
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Western Digital 500GB won't turn on.
If nothing is broken inside the harddrive it is possible to retrieve the data, all you need to do is take the hard drive out of its housing and plug it into your dvd drives slots, eg, using the power supply cable and the cable that actually reads the info from the dvd drive. once this is inserted boot up computer and see if your computer reads it. i have personally done this with my broken external and it worked, but note it only seemed to work in the first dvd drive so you may have to unplug your first dvd drive.
hope i helped
josco91 =)
Jun 23, 2009 | Western Digital My Book Essential Edition...
It whirs for a few seconds, stops, then whirs again for a few sec
The hard-drive is "dying".
Is it still under "warranty"?
When you have the serial-number of the hard-drive inside the external unit, access Western Digital's web-site, and check the Warranty Status.
Note that Western Digital (the maker of the external drive)
has a "Customer Loyalty" program. Enter the serial-number
of the hard-drive on their web-site, and you can purchase a new external hard-drive at a significant discount.
Jun 01, 2009 | Western Digital My Book Essential 500GB...
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Western Digital 500gig External Harddrive. Power up troubles.
this is a bit tricky , you'll need to tell my what operating system you have ,
more than likely sounds like windows power management is turning the drive off
check your power management settings.
if thats not the case just let me know.
shalom
Aug 20, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
275 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
