When turning on the tv there are colored lines on the screen and the sound would be ok. it would not matter on the source the sound would come through fine or the tv would not turn on and a red light would flash 5 times
    Genius:
  • Televison & ... Master
  • 2,432 Answers
It needs trouble shooting but try first minor option if you can open your flat TV then re soldered parts. in this case the problem was in video and color section try to look cold solder parts like IC, resistor and capacitor re soldered all this.then your last option is to check leak or defective parts which may cause color interference in your screen.
Posted on Apr 10, 2011
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
When I power on my TV, display comes right on. To The left on my screen I have 3 vertical lines....2 are close together and the other line is about 1inch away, each solid line is a solid color, after 25...
Fix this problems many times,if the colors strips lines problems are cause by the tv,not by somethings or someone hitting the LCD screen panel,than the screen panel is not repairable.This problems is the cause of the board call the T-CON decoders board.The T-CON decoders board have problems.This T-CON decoders board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 20, 2010 | Samsung LNT5265F 52 in. LCD HDTV
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
On an LCD TV? Sounds like you've got a bad TCon board.
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Jun 07, 2008 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
