Question about Motorola T5410 (14 Channels) 2-Way Radio
Expandability I have a Talkabout T5410. It has two handheld units and I need 1 or 2 others. Are there any models I can buy that will be compatible (able to communicate) with the set I already have?
  • Motorola Master
  • 1,654 Answers
Any of the FRS radios on the market should be able to communicate with your TalkAbouts. Most have the typical 14 or so FRS frequencies installed. Your T5410 has an interference eliminator, when set to anything other than zero, it will block out other users on your frequency. If you use this option, you will need to chose radios with this feature. Some of the cheaper off-brands do not offer it.
Posted on Aug 07, 2008
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
I lost one on my t6500 talkabout, what can I do with the one remaning? can I use it whit a new pair?
Yes, other TalkAbout radios are compatible with the T6500. Most of this series of radios have the 14 FRS frequencies installed.
Bestr regards.
Jan 05, 2011 | Motorola Talkabout T6500 (7 Channels)...
Where can I buy repair parts for my Motorola T5720 Talkabout radio?
So sorry, parts have never been available for the TalkAbout line of radios (other than TalkAbout Distance & DPS). If you are looking to repair an existing T5720 unit, your best option would be to locate a like-model for parts. eBay can be a good source.
As for replacement batteries and accessories you can use the Motorola TalkAbout Accessory Store.
Best regards.
Mar 20, 2010 | Motorola Talkabout T5720 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
HANDHELD UNIT NEED ADAPTER TO GET DIGITAL SIGNAL NEAR KCMO
To connect a converter box to a handheld TV that has an external antenna jack, you need an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 12, 2009 | Casio TV-980 2.3 in. Handheld Television
T5410 I press MON key and it doent make sounds
It sounds as though you have a broken speaker. Do you have a head phone/earphone jack on the unit. That would be a good test.
If it does have an earphone jack, they have been known to get trash in the jack, that in turn breaks the circuit to the speaker.
Mar 31, 2009 | Motorola T5410 (14 Channels) 2-Way Radio
Wanting to know how far this radio will communicate
In reality, handheld radios will talk line-of-sight up to 2 miles. When talking in and around buildings, the range can be reduced to as low as 1/4 to 1/2 mile. For optimal range, be certain to hold your radio with the antenna pointing straight up (perpendicular) to the ground. Height and placement of antenna determines range.
All that being said, many radio manufactures make claims of 5, 10, 18, 25 miles. These claims would be true if one radio can see another, such as talking from a mountain top to a valley. In the real world, we deal with curvature of the earth, hills, buildings, etc.
TalkAbout radios and the other FRS radios operate on 1/2 watt FRS, and 1-2 watt GMRS frequencies. Business radios on the other hand operate on up to 4 to 5 watts of power. The power does not always equate into extra range, it does however, provide much greater clarity in the fringe areas.
Hope this answers your question.
Jan 19, 2009 | Motorola Talkabout T5720 (7 Channels)...
The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 16, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola T5410 (14 Channels) 2-Way Radio Logo
107 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
