Question about Kenmore Sewing Machines
I can thread my machine but when I try and catch the bottom thread (in the bobbin) it wont catch. Im not sure why
  • Kenmore Master
  • 1,133 Answers
Check that the needle is in correctly, flat shank to the back. This is first thing to check as the hook rotates around and catches the thread from the back of the needle as the two come together to form the stitch. So if the needle is in wrong, the scarf at the back (scooped out area) won't be there and no stitch. Make sure needle is inserted fully up into the housing and that it is the correct system needle (most machines use the 130/705H system). Put in a new needle from the pack to make sure.
Is the bobbin in properly, rotating the right direction and under tension. So check needle, check bobbin, rethread everything and try again.
There is good general machine info on www.sewing.about.com which might help you too.
Less likely but it does happen, is the timing could be out, so the needle at the bottom of its movement and the hook swinging around it are out of sync. Timing can be knocked out if there has been a jam up, needle striking the sewing foot or something similar. If you suspect that this is what is going on, then probably time to take machine to a technician who can repair this.
Posted on Apr 10, 2011
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
Needle will not pick up bottom thread
Try a brand new needle. Verify it is installed correctly.
Remove the bobbin. Check that the bobbin is turning the correct direction and the thread is threaded correctly in the bobbin case. Reinstall the bobbin case and make sure that it latches.
Retest your machine. Manually turn the handwheel and watch the needle descend and see if the thread picks up the bobbin thread. If not, then the machine may have a timing issue. Take it for service.
Nov 01, 2016 | Sewing Machines
Why needle is not catching the bobbin thread
All problems like this are caused by incorrect threading of the cotton thread. Even if you have done it before, thread the cotton using the instructions in the manual.
Also make sure the bottom bobbin and its housing are correctly inserted.
Aug 15, 2015 | Singer 3321 Talent Sewing Machine
Bobbin is not catching thread
NOTE TO THE QUESTION. Bobbins do not catch thread. A hook underneath when you use the wheel to advance the machine will come and catch the under thread OR BOBBIN THREAD and pull it up.
Something common and I do it, wrong bobbin in the bottom thread. I have 2 sewing machines so put thread on both plastic and metal bobbins and then just grab the wrong machine bobbin.
If this is not the issue, take the machine apart and clean it well. Note the spots that you are to oil SPARINGLY.
Aug 30, 2014 | Sewing Machines
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
try changing the needle
also try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way in the bobbin case
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Jan 15, 2013 | Sewing Machines
BOTTOM THREAD WONT CATCH
are you sure you have the bobbin in correctly? I mean most machines require that the bobbin un-spool in a specific direction to work properly. Also make sure your needle isn't damaged or bent and is inserted fully into the needle bar.
Good luck
Jul 29, 2012 | Sewing Machines
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Sep 07, 2009 | Singer 7436 - INGENUITY
Sewing Machine (brother XL 3200) When I attempt to thread the machine I get to the part that I want to catch the top thread that goes through the needle with the thread that is in the bobbin and usually...
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Jul 19, 2008 | Brother XL-3500
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
