Question about Sanyo Televison & Video
DVD disc will not play - only has "disc error" in the upper right hand corner after it shows that it is reading. Thank you, Geraldine Halpin
  • jerry121629 Apr 13, 2011
    Thank you so much. Your suggestion worked like a charm. Jerry Halpin
    Yes, the solution was very helpful.
  • Sanyo Master
  • 11,800 Answers
This message signifies that the sensor from the reading head of the player does not detect the reflected laser beam. If you are sure that the disks are ok then the sensor and the lens above it are covered in dust.
If this isn't a long standing problem then the dust can be cleaned with the help of one of those special cleaning disks that you can find in every electronics shops.
But, because the lens is made out of plastic, if you have left this dust in place for too long then it has been baked on the surface of the lens so the cleaning will be too little,too late. This dust cannot be removed so the entire dvd mechanism is defective and it will have to be replaced by a repair shop at a great cost.
Posted on Apr 11, 2011
My toshiba dvd/vcr combo suddenly wont read dvd disc
Maybe the lasers ok but the disc motor is not spinning the disc.
Apr 28, 2014 | Televison & Video
Why does my DVD player say STOP in Upper Right Corner?
Sounds like your laser mechanism is no longer capable of reading a disk. If it does it with other disks then you can be sure of the diagnosis.
And due to parts cost and labor a repair is usually not cost effective.
Apr 28, 2012 | Magnavox DP170MW8B DVD Player
Won't play dvd's
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens.
Aug 12, 2009 | Philips Magnavox DVD/VCR Dual Player
My Sharp Aquos blue ray player won't read all blue ray dvd's, why
You need to force the player to the the Top Menu of the disc.
The way to do this is: load disc, wait until it says "Reading Completed" (about 1 minute).
Wait for the PLAY icon ">" to show in the upper right corner (this may take up to 30-40 secs).
Once you see the ">" Hit the STOP button on the remote to get to the player's splash screen.
From the Sharp splash screen Hit the "Top Menu/Title List" button on the remote and wait for the circulating dots and then the disc menu appears.
Play the movie from the menu and you should be good to go.
~JC
Jul 16, 2009 | Sharp BDHP20U Blu-Ray Player
Disc won't play
try cleaning the lens
Jun 07, 2009 | Coby DVD-224 DVD Player
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
CD won't play
Your lens might be dirty.Open the cover of player and identify the lens.Its a little glass eye.Get a clean cotton cloth dipped in methylated spirits gently rub surface of lens. Give some time to dry and replace cover.You should be ok.
Jul 19, 2008 | Cyberhome CH-DVD 300 DVD Player
Freezing
damaged or dirty disc-clean or replace
ron
Dec 27, 2007 | NexxTech DP3222 DVD Player
Trutech dvd player
Is that CD Player or DWD player????
Oct 25, 2007 | Audio Players & Recorders
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Televison & Video Logo
252 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
