Question about Schiller Cardiovit At 2 Light Ecg Machine
At-2 lite model not printing visibly patient data and interpretation also have blurred upper part of EKG print. All leads are printed well. Is this setup problem or malfunction?
  • Schiller Master
  • 6,694 Answers
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
Posted on Apr 18, 2011
The machine prints Lead I but nothing else. What should I do?
Your print head probably needs adjust. The Schiller ekg machines are notorious for these issues. You may want to send the machine in. We/ Discount Cardiology will look at your machine for free and call you with a diagnosis. I am 99% sure that this is the issue.
Aug 23, 2012 | Schiller Welch Allyn Cardiovit At 2...
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
Schiller AT-Plus, I cannot get all leads to print in sequence I avr v1 v4 II avl v2 v5 III avf v3 v6 not sure what a student did to change the...
The unit is apparently printing out in Cabarra sequence. To restore the correct lead sequence, do the following: Hit the ALT key followed by 7 then 1, hen the stop key. This will restore standard lead sequencing.
That is the start of the battle. If you desire a 3+1ryth format with a lead 2 at the bottom, which is our standard format, then you have more to do. For this format hit the ALT key followed by 1 then 0 followed by the stop key.to set the ryth lead to lead II at the bottom of the page, hit ALT followed by 3 then 8 then 2 followed by the stop key. If your filters are not enabled hit Alt 5 6 stop, alt 5 8 stop, Alt 8 3 stop, ALT 8 1 stop.Do a test print after all of this and be certain the unit is configured to your taste prior to a live patient.
Jun 14, 2011 | Schiller Welch Allyn Cardiovit At 2...
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Machine boots up properly. You can enter patient data, switch between scales/ranges, etc. You can select the ALT functions. The problem comes when I try to print. If I press "Auto Print", it...
hi,
ur Schiller at 2 has problem with its battery. just replace the same. its a12v battery.
also clean the paper sensor With an ear bud (do not use any chemical use only ear bud). u can see the paper sensor on the side of printer head. a small square black portion.
ok
Nov 29, 2010 | Schiller Welch Allyn Cardiovit At 2...
How do i know if my ekg is interpretative?
Sometimes you can print out a report even though you are not connected to a patient. If a report prints out you will see "interpretation" on the top middle of the page. If interpretation is not there it most likely means you do not have interpretation. You could also call welch allyn and give them the serial number. They will be able to tell you.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jul 18, 2010 | Schiller Welch Allyn Cardiovit At 2...
Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
Jun 10, 2009 | Schiller Welch Allyn Cardiovit At 2...
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Looking to buy for home use
Hello whosyerdaddy, the differance will be a print out informing you of detected adnormality in the waveforms. Interpretive is selected an adnormality may state an "AV weak" . A non Interpretive will state no adnormalitys detected in the the waveform. You will need to read all the waves for any adnormalitys.
Oct 24, 2008 | Medical
Schiller Cardiovit At 2 Light Ecg Machine Logo
222 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Are you a Schiller Medical Expert? Answer questions, earn points and help others
