PANASONIC CT-36D12D turns off intermittently. Comes back after a few minutes. rinse and repeat. User serviceable part? Please advise. Byrd ~,~
  • 1 more comment
  • krbyrd64 Apr 20, 2011
    Apologies. Just seeing this. It comes back on by itself after X minutes 3-5 as I recall, on for 10 minutes or half an hour and out again. Have not correlated this time line in winter w/ furnace cycle given close proximity to register, except confirming incidence w/ no heat on. (5 ft below ceiling vent indirect angle) rb~,~
  • krbyrd64 Apr 21, 2011
    Thanks. We'll give that a go. Will advise outcome - logistics will weigh in, as this is a 150# TV, currently on Kitchen table. ...Access to 120v though. Confidence is high as we approach this lab trial.
  • krbyrd64 May 10, 2011
    dust not too bad. all components appear reasonably clean and sound. rb
  • 4,889 Answers
When you say comes back after a few minutes, does it mean that it comes back on by itself, or can be powered on again after its off for a while? Please provide this info so that I can tell you what the problem is. Sounds like an over-heating issue to me.
Posted on Apr 10, 2011
  • 1 more comment
  • eagle338
    eagle338 Apr 20, 2011
    There are other causes for overheating such as dust. The first thing to try would be to take a can of compressed air, remove the back cover of the tv and empty it on the boards. If its a dust related issue, it should be cleared.Please try it and let me know
  • eagle338
    eagle338 Apr 21, 2011
    :) I hope it will work. I should caution you though not to venture close to the CRT. We are dealing with a device that operates at 30,000V which are generated by the high voltage transformer(flyback). Also look for any capacitors that have bulged or cracked tops as the overheating may have damaged some capacitors.
  • eagle338
    eagle338 May 10, 2011
    Hi I am down with a terrible stomach upset . I will get back to you as soon as I am Ok.
My panasonic tv not turning on
Check and replace faulty component/s in the main power regulator section circuit. The SMPS is not functioning.
Aug 26, 2012 | Panasonic CT-36D12D 36" TV
PANASONIC PORTABLE TV
What is the faut with your tV?
May 11, 2012 | Panasonic CT-36D12D 36" TV
When hooked up to a x box 360 everything is black and white
change the output on the xbox in system settings > console settings > display from pal to ntsc or ntsc to pal. That is the reason it is showing in black and white
Apr 22, 2011 | Panasonic CT-36D12D 36" TV
My tv turns on properly but after a few minutes it goes blank
you are having a heat related issue and the component or parts are failing. using a hair dryer blowing into back of set will make it black out and a portable fan should cool it enough to come back on. unless you know a good cheap tech, repairs are costly. i left the business when t.v' s became disposable.
Sep 21, 2009 | Panasonic CT-32D10 TV
I have a Panasonic TV Model#CT-35625B, How do I remove the closed caption?
It is in video options if is not present then video contains subtitles, to clean it is possible through options.
http://www.cellphones2009.bravehost.com/
Aug 08, 2009 | Panasonic CT-36D12D 36" TV
Picture on and off
these arent easy fixes,have them serviced
May 19, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
Panasonic CT-36D30
bad solder connections get back to me if this did not help
Nov 01, 2007 | Panasonic CT-36D30 TV
Pansonic CT-32HXC14
This is a bad connection in the power supply, or a bad connection in the high voltage supply, and could also be expensive to repair if the regulator board is intermittent. I say if you can take it back, good riddance. Good Luck
Jul 27, 2007 | Panasonic CT-32HXC14 32" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
