Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Battery does not last
Genie garage door will start going up and down by itself, thought it was the Genie but changed the 9volt battery in the Chamberlain outside key pad (which is inside the garage) and problem quit. But the new battery will last only a week and opener starts to go up and down again. Changing the battery solves this problem, but, battery only last about a week and problem starts again until I put another new 9 volt battery in the unit. Why?
  • 504 Answers
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
Posted on May 30, 2010
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Aug 15, 2009 | Genie Company Genie 34538S Chain Glide...
Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
199 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
