Need to disassemble and change screens - Computers & Internet
    Sergeant:
    Champion:
  • 207 Answers
Youtube has a great set of users who are willing to give free step by step proces for changing screens it is realy not too hard for some so go there and try it if not come back to me i'll help u threw it.
Posted on Apr 10, 2011
How do I change the lcd/vga cable on asus v550ca laptop
A flickering screen indicates a backlit problem. I would personally change out the screen but if you want to do a complete diagnostics and take the long way in which you'll learn a lot.
Tools needed:
Dollar store jewelers screw driver set.
Soft cloth towel
To replace the screen only:
On the screen there's little screw covers on the corners of the screen, removing these sticky little covers will give you access to the screws that hold the screen cover on. Once removed get a guitar pick or even a finger nail and go gently around the screen. Once the screen cover is off you will see the screws that hold the lcd in place and screws that secure the hinges.
Locate and remove the screws that secure the lcd to aluminum side rails. Use the soft cloth towel to protect the screen from getting scratched during removal. Lower the screen towards the keyboard and lay it down on the keyboard.
On the back of the screen you will see a ribbon cable attached to the back of the lcd screen. GENTLY pull down the ribbon cable lock on both sides of the ribbon cable.
The only thing left connected to the screen is the backlight cable, GENTLY pull this plug out taking note of what color wire is on the top and bottom.
Reverse this instruction and happy computing
For COMPLETE laptop dis-assembly follow this link:
Follow this link for complete disassembly instructions with pictures for your laptop. You may want to skip to when the screen gets disassembled.
http://www.insidemylaptop.com/how-to-disassemble-asus-v550ca-db71t/
-Mark
Nov 21, 2014 | ASUS Computers & Internet
Replacing a LCD screen Nikon D3100 How to do it?
hello, to disassembly the nikon d3100 and change the lcd you need the disassembly instructions and pictures i had found a official service manual that has them and it will help you with that ,you can download it from the below link:
http://goo.gl/AvZHV
Good Luck
May 19, 2013 | Nikon D3100 Digital Camera
Acer 4745g black screen problem
So, if you can hear startup sound then motherboard, RAM and HDD is OK! Try to connect it with external monitor, if it's working on it, then problem in LCD, LCD light or LCD cable. If not working with external monitor then it is video card problem, if card is integrated then you need to reball or change at all south bridge on the motherboard, if video is as module card then just replace it with compatible one.
If LCD cable - disassemble laptop to get LCD cable and test each wire with any multimetr with sound beep and replace it if needed.
If LCD light - try to take LCD screen under good lamp then power on laptop and carefully look to dark screen if you see very dark Windows boot screen then you need to disassemble LCD housing, disassemble LCD, remove and replace LCD lamp with working one.
If all this cant help, then you need to replace LCD at all.
Nov 15, 2012 | Computers & Internet
The green power light on my tomtom XL is on and is fully charged however the screen wont turn on and remains black, it also makes no noise.
First you need to check if the battery is okay, try it on another tom tom gps receiver, if it is working and the screen wont turn on, then it means there is a hardware problem, probably the flexi ribbon that is connected to the screen is either loose or bad, this will require you to disassemble the tom tom and check for the flexi ribbon that connects to the screen, then you resit it or change the ribbon, that should do the job.
You can also try to reset the tom tom first before disassembling it. By pressing and holding the power on/off button for about 15 seconds, if that does not do the job, then you can go ahead and disassemble the tom tom.
Hope this solution helped
Dec 22, 2010 | Tomtom ONE XL-S GPS
How do u change the screen on a d900
For change LCD is not necessary to disassemble all the phone remove only the four screw behind the screen (2 up and 2 under battery) ,remove flex cable and replace LCD.
Not necessary to disassemble the mothrboard.
Sep 09, 2009 | Samsung Cell Phones
Changing gateway 6021gh lcd screen latch
there are rubber bumpers around the screen that can be taken out by a screwdriver and underneath are the screws for the disassembly process
Mar 12, 2009 | Gateway MX6214 Notebook
Change cracked screen over to new screen
If you require a new screen, phone cover and screwdrivers, they can be purchased here: http://www.formymobile.co.uk/proddetail.php?prod=viewtylcd
You can also visit :http://www.formymobile.co.uk/viewtydisassembly.php for dissasembly steps.
If you have any questions about LG Viewty KU990 disassembly, The official service manual for this phone may also help you with further LG Viewty KU990 disassembly.
Nov 27, 2008 | LG KU990 Viewty
Sidekick 3 crack screen
Yes you can purchase a screen and replace it yourself.
check out Sidekick LCD screens
They run about 50 dollars new and come with instructions.
For the person with an extra sidekick, check out Sidekick 3 disassembly YOu will need a screw drive with some special bits
Nov 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
