Try this
An '0x ...' Error Message Displays on the Front Panel When Printing
Issue
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .'
Important: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error:
Solution one: Reset the product
1.
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon
Figure 2: Example USB connection (your product might not look exactly the same as this example)
Description of disconnecting the USB cable.
2.
Remove the cartridges from the product.
3.
Wait for the 'Insert Cartridges ' message to display on the control panel.
4.
Disconnect the power cord from the back of the product.
5.
Wait 60 seconds.
6.
Reconnect the power cord. If the product does not automatically turn on, press the Power button
7.
Reinsert the cartridges, and then close any open doors on the product.
8.
If you receive a prompt to print a calibration page, do so.
9.
Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
If your product is in warranty , contact HP.
If your product is out of warranty , click here to view additional printer support options starting as low as $20.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
