Question about HEWLETT-PACKARD HP Pavilion dm4-1162us Notebook
The latch is stuck on my new hp dm4-1160us laptop. tried to follow the directions of fixya, but no luck yet.
How to open hood if the cable for hood latch broken
try taking the wheel liner out on the side of the stuck latch and access the latch directly you can open it by hand if u follow the cable to lever. if you cannot access from wheel ull have to go from under the bumper as a last resort ull have to unbolt the latch while connected which can be tricky
Jan 27, 2014 | Audi A8 Cars & Trucks
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Hp dv2000 battery latch stuck
I am just gonna post my answer to another, like question. BTW, this seems to be a design flaw. Do not know if HP made them this way to keep maintenance busy, or they just do not have a clue. Here was my solution, which was found on a similar question. - The HP Compaq Presario CQ62-417NR Notebook PC, which was the "newest" model in stock when I bought a laptop June 2011 has the same design flaw. Crappy plastic latch, that gets stuck in the open up position. One must be careful when putting a battery in to be sure the stupid crappy latch is not stuck all the way over to where they pushed it to get the battery out. Mine was stuck big time. Thanks to the comments on here I found my solution, which is the only one. (I am not going to risk taking a computer apart to re-set the latch; some times I lose my car keys for days on end, so taking it apart is not an option for me) My solution was to use one of the little flat head screw drivers - 3.00mm. I was able to slide it into a small crack on the side long part of the battery opposite the dvd drive, give it a small tug and the battery popped out. The latches are so cheap mine broke when I first encountered the problem because I tried to force the long knob. I did not realize it was in the open up position. Words of caution. Just pop the battery out, and you may save the latch knob. Just be careful when popping the battery out to stay away from the side where the contacts meet. A screwdriver could potentially cause problems in that area (towards the dvd drive). Cheers!
Feb 08, 2011 | HP Pavilion dv2120us Notebook
I own a HP Scanjet 4850. Please give me information on free driver software. I want to connect my scanner to my laptop, Windows 7. I want to scan photos and save them to a cd. Thanks...
On this link you will get the official driver for your scanner for Windows 7 (32 bit). Download it, run it and follow the on screen guide. This is just about the drivers. About software, you can use any image editor software you like, at the programs - accesories is already the Microsoft Paint. You can also try Gimp from this link. It's a freeware remarkable editor. The procedure more or less is the same: start the program and go to "file" - "import from scanner". Follow the on screen steps.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 07, 2010 | HP Scanjet 4850
The latch on the laptop broke How do i open it?
you need to mimic what the latch did most latches are like arrows in this case get two thin items ( blunt butter knifes) and move the latches both left or right if its a middle type latch then try pushing in were the broken latch was .get what i mean if the old latch pushed in then its a middle latch if it slide then is double arrow latch ounce the laptop is open if you dont want to spend $$ fixing the lach just cut of the locking arrows to stop it locking again
good luck
email me if need further assistance
Jun 25, 2010 | HP Pavilion dv1000 Notebook
I don't have audio driver in my laptop and i want to download it
If you let us know your operating system type, we can help you better, anyway open this link (hp website) hpcompaq presario c500 drivers Select your operating system type and follow the instructions, this is the direct link for your laptop. Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP Compaq Presario C500t Notebook
HP Pavilion dv6225us laptop battery release latch
is the latched stuck in the open or closed position? if it is in the open position you may be able to wedge a pick or small flathead and gently ease it out. if it is in the locked position attempt to use one of these same tools to move the latch to the open position. hope this was helpful.
Dec 09, 2009 | HP Computers & Internet
Door latch is stuck
The latch mechanisim may just be jammed. You can try accessing and pulling on the manual release to see if this will reset the latch and enable you to close the door. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have questions, or need additional assistance, please let me know. I hope this helps you.
NOTE: The Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Sep 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Hp pavilion dv1000 backlight invertor
Hi and welcome to FixYa,
Appreciate the direct "Ask Me"
The inverter would the the elongated PCB below the LCD screen.
They would be available here, here or here.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | HP Pavilion dv1000 Notebook
Cannot install new color print cartridge for HP 6988
Do NOT force it! Ensure you're following the manufacturer's directions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=130&prodSeriesId=468002&prodTypeId=18972&objectID=c01129395
Oct 28, 2008 | HP DeskJet 6988 Printer
HEWLETT-PACKARD HP Pavilion dm4-1162us Notebook Logo
193 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
