Question about Actiontec (5GE583000-01) Router
How do I connect my Action tec router V1000H to other computers to be able to print to ne printer. Iam running widnows 7
I used a hamer
Posted on Jan 12, 2012
    Problem Solver:
  • 40 Answers
1)make sure that the printer is capable to be a network printer.
2) make sure that your able to print with main computer on the network.
3) make sure that the printer was able to detect the network via wireless connection ( if the printer have wireless capability) ( if not then it should be connected with a ETHERNET cable directly to your router)
4) make sure that the other computer already have the driver of the printer.
try using this first and if this will not work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Posted on Apr 10, 2011
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
I cannot get the printer Canon MX870 connected to the computer network. I am running windows XP I have it connected to the home router but when I put in printer name while adding the printer on the...
You cannot just add network printer on Windows XP without the printer software. You can only install it on Windows 7 with no software.
You need to get the canon MX870 software and run it on the computer you want to print files from. 'Before you do it, make you have already setup the printer to connect to your router and also make sure that it is connected to your router before you run the software.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Select Windows XP (NOT WINDOWS XP 64) then download and install the first file "mp68-win-mx870-1_04-ea24.exe" Run it and it will show you options. Choose setup wireless there you go! Make sure you are connected to the-same router the printer is connected to.
Please rate 4 stars if this solved your problem. Thanks
Apr 26, 2011 | Office Equipment & Supplies
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Cable structure
DB25 F DB25 M
(Computer) (Printer)
2 2
3 3
4 4
5 5
6 6
7 7
20 20
DB9 F DB25 M
1 8
2 3
3 2
4 20
5 7
6 6
7 4
8 5
Dec 08, 2009 | Toshiba TEC B-472 Thermal Label Printer
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Actiontec (5GE583000-01) Router Logo
449 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
