How do I get to the pump or valve assembly on a whirlpool calypso washer
    Brigadier General:
  • 6,277 Answers
(try following these)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
My Calypso washer at the start I hear water filling tub. Then it stops filling and hear a moderate humming noise. I replaced water pump but still doing the same. Please help. Thanks
The problem is not the pump. IT appears that the water control valve is bad or the voltage that controls it is changing and then the valve stops working.
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
Flood Condition:
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Caypso Washer is flashing FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&!$$
Dec 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Leaking
try replacing the drain hose where it connects to the pump? perhaps the pump itself had something caught up in it, i own one of these machines as of a few days ago and i aquired it with it not draining, after i cleaned up the pump and put it back, all is good... check your pump assembly if possible or run it thru with the front panel off to see where the leak is coming from.. directions are avaliable under the owner center on whirlpool.com just enter your model # in and look for a parts diagram of the cabinet...
good luck..
Apr 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Had the ld code i checked the discharge hose and replaced .
I experienced many LD's over the years with my whirlpool calypso. My non-technical solution (not recommended but it usually worked) was to push an electrical "fish tape" down the discharge hose trying to dislodge some debris. That process was successful about 90% of the time.
Perhaps the better solution is to take the back off and look at what I believe is a check valve contraption. That piece has about four hoses that attach to it. What I recently did was remove the hose on the left side as you face the back of the washer (closest to the back wall of the washer). I then found a suitable instrument that I could shove into the valve assembly and hook onto the big clump of debris that had collected in the valve assembly. By the time I was done there was about a baseball size clump of lint and hair and who knows what............but the washer did drain freely after that ............(until the U-Joint failed).
Bought an LG.
May 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
