Question about Necchi 4575 Mechanical Sewing Machine
Needle will not pull bobbin thread thru neddle plate.
    Genius:
  • 1,788 Answers
There could be a simple solution or one that needs professional assistance, try inserting a new needle with making sure that the flat side is facing away from you. Also, try a light sanding in the hole that the thread comes through. Try rethreading with different thread and making sure that you leave enough of a tail on the bobbin thread. If, this does not work you may need to have the timing checked. good luck
Posted on Apr 10, 2011
Top thread will not loop bobbin thread
Try re treading it. After you have guided the thread thru the eye of the needle turn the wheel until the needle goes all the way down. Keep turning and as the needle starts to come up pull on the needle thread and it should loop the bottom thread and pull until both come back to the top. Now you are ready to sew.
Mar 11, 2015 | Singer 2662
I HAVE A TREADLE SEWING MACHINE IT LOOKS JUST LIKE A BRUNSWICK BUT I'M NOT SURE IT HAS THE NUMBERS 3242620 UNDER THE FRONT BOBBIN PLATE AND MADE IN THE USA ON THE BACK OF THE MACHINE I AM HAVING...
try a new needle or if it is a new needle make sure it's in correctly
make sure there no lint or loose threads in the bobbin shuttle area
it may need to be serviced
Aug 03, 2011 | Sewing Machines
Neddle will not pick up bobbin thread
Check the needle to see if it's damaged
check the needle to see if it's in backwards
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 28, 2010 | White Sewing 1521
The thread bunches up under the material when i sew. thread then clogs up under the plate.
first start with the needle & see if it's bent-roll the needle on a flat surface & see if it roll correctly
when a needle is blunt it makes a popping sound when it goes thru the fabric
check the bobbin to see if it's warped-I have had some that were
check to see if there is lint or loose thread in the bobbin case area
rethread the machine to make sure the upper thread is not catching on anything
sometimes the thread can come off the thread take up lever
& sometimes it can get caught on the spool pin & also on the notch that's on the thread spool it's self---I've had this happen before
if you sew alot-good maintenance practice is to clean the bobbin case area at least once a week-if you don't sew alot-once a month & also under the needle plate
when cleaning under the needle plate-make sure you do not damage the top of the screws when you remove them to clean under the needle plate & because if the top of screws get damaged they can pull the fabric when the fabric goes over them
check also to make sure your top tension is correct
Sep 02, 2010 | Brother LS-2125 Mechanical Sewing Machine
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Needle doesn't connect with bobbin
hello there, do you mean you can't hooked up the lower bobbin thread to neddle bobbin thread, all you gonna do is to check the bobbin winding thread if it is in clockwise rotation when you pull out on the bobbins casing, insert the shattle casing, then manually rotate by your hand try to hooked up the bobbin thread by your neddle thread. let me know if you got it
regards.. rated me thanks
Mar 31, 2009 | Sewing Machines
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Not catching stitches / bobbin correctly
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Oct 05, 2008 | Bernina Bernette Deco 600
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Necchi 4575 Mechanical Sewing Machine Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
