Question about Dell Dimension 2400 PC Desktop
The user mode screen
The user mode screen keeps popping up , pushing the exit button on the front of the monitor will get rid of it for a short time .
  • 876 Answers
It is asking you to set your user mode. That the color is a bit off or whatever. It is probably going to continue to do this until you set it and ok that setting. Do you have the little booklet that came with your monitor or your dimension manual. You should be able to find the information there. If not, You can do to www.dell.com and look for dowloads, where you can download the manual or view it in PDF format.
Any other questions let me know.
Posted on Aug 18, 2008
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor settings screen keeps popping up
it happens due to excess moisture in air when the switch gets shorted by itself due to dust accumulation ,If in warranty pls log a call or else get it checked by a monitor repair person all monitors have same switch's
Mar 20, 2013 | Dell Computers & Internet
Get rid of eo
Press MODE. Highlight "NORMAL" on the first line and press ENTER. Highlight "FLOAT" on the second line and press ENTER. Exit the mode screen by pressing 2ND [QUIT].
Nov 19, 2012 | Office Equipment & Supplies
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
Why is there a small print on my screen
It sounds like the Monitor adjustment button is engaged or hanging is there anything leaning against the buttons say the back of the keyboard or something may have bumped it hard and caused it to sit funny. Esp. since you said you hit the exit. That display is for adjusting the monitor for size of image brightness contrast screen position. You may have the screen size set too large to get to the whole menu. Check the button issue first, someone once had some pop spray the screen and the dried sticky coke cause the button to stay partially down. Please unplug the monitor if you use any liquid to clean the button to avoid a short or shock.
randy320sgi
Jan 08, 2009 | Compaq CV 7500 17" CRT Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Dell Dimension 2400 PC Desktop Logo
65 people viewed this question
Alun Cox
