My toshiba tv (42pw23p) is not working. i switch on the television... there is no visual image but the sound works? can u help me?
  • pendragonuk Nov 16, 2008
    Hi, I have a Toshiba rear projection screen TV 42PW23P. It has seen under 100 hours of use since new. This morning I turned it on and the green light kept on flashing. No picture or sound. I have just turned it on again and the green light is no longer flashing and I have sound, but no picture. Can you advise me please on what is wrong and what sort of cost for a repair should I be looking at or is there something I can do myself? Warrantee ran out over 1 year ago....Regards, Keith
4 Suggested Answers
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: toshiba help!
model number?
Posted on Mar 17, 2008
  • 476 Answers
SOURCE: picture on tv has blue and red going through the
try to align it by going into the convergence setting in your on screen menu, some proj tv have a multipoint conv alignment, this might do it for you, if it doe not then therre might be a problem with the red and blue convergence amps and on this model the digital conv module(dcm) can also be at fault.
Posted on Aug 05, 2009
Ecollier2012
  • 3459 Answers
SOURCE: TOSHIBA 42PW23P rear projection television
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Hi, I have an old Toshiba 42pw23p which hasnt been used for 4-5 years now, I wanted to see if it works, once plugged the red light at the front appears and the power seems to be there, however when I try...
The hard drive boot sector has failed and this could be from inactivity, heat or cold from being in storage, or the unit could have been bounced around at times. Once the drive is inactive it cannot be restarted.
Feb 20, 2014 | Toshiba 42HDX82 42" Rear Projection...
Need user manual for toshiba 42pw23p tv
This is an older Toshiba model. So the manual has to be accessed through the older models site: ftp://195.35.123.32/CCFTP/Manuals/ . The specific list of manuals for the CTV Projection TVs 42pw23p is here: ftp://195.35.123.32/CCFTP/Manuals/CTV%20Projection/40%20TO%2050%20INCH/42PW23P/ . The manual is available in several languages and as .zip or .pdfs. The direct link to the English version (pdf) of the manual is ftp://CCFTPcustomer:[email protected]/CCFTP/Manuals/CTV%20Projection/40%20TO%2050%20INCH/42PW23P/42PW23P%20English.pdf .
If you have trouble accessing the FTP sites, start here: http://portalcp.toshiba-tro.de/ and click on the Owner's Manual tab. Then click on the LCD TV link and choose the link for pre-2008 models (just above the model selection drop downs).
I hope this helps.
Nov 01, 2011 | Televison & Video
Toshiba 42PW23P colours are not merging together. You can see the colours separately. Think this may be a convergence problem or rainbow effect
Yes,ur convergence is dead.Must replaced these 2 convergence ICS and all it resistors to solved this problems.The shop well cost u $300 for parts and labors.
Feb 10, 2010 | Toshiba 42H81 42" Rear Projection...
Picture on tv has blue and red going through the top and can people look like they had 2 heads on tv toshiba 42pw23p
Aug 05, 2009 | Televison & Video
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Oct 21, 2008 | Toshiba TP43H95 43" Rear Projection...
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
TV Toshiba 29VH27DP colour television
I have disassembled the TV and have found out visually, that the power unit, now replacement of a power unit has broken down will lead to to normal work of the TV
May 29, 2008 | Toshiba Televison & Video
Pionneer DV-393-K
Hi there, I have the same problem. Is your screen blue on the TV when a movie is playing on your DVD, however the sound is playing on your TV?
Jan 13, 2008 | Pioneer DV-393-S
No picture, sound works. Screen flickering
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
