Question about Dayton Gas Furnace Heater
Furnace blower runs continuously but no heat - Dayton Gas Furnace Heater
  • 413 Answers
Sounds like the furnace control (low voltage) circuit is open, or in other words you either have a fuse blown or a limit switch that needs to be reset. Most newer furnaces have a small knife like fuse, usually 3 or 5 amp located directly on the circuit board. Limit switches that have a manual reset are usually located in the fire box just above the burner. There may even be a limit switch located on the blower assembly. If you fuse was blown, you may need to find out what caused the short in the circuit or it will do it again. If the limit switch was tripped, you need to turn the furnace back on and watch the flame to see if there is "roll out". It it continues to trip or blow fuses you need to have the unit serviced.
Posted on Apr 10, 2011
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Posted on Nov 03, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
We have a White-Rodgers 1F80-51. The fan blows
May 31, 2010 | Heating & Cooling
When furnace runs blower won't run.as soon as furnace stops blower runs. They never both run.
Sounds like fan limit switch/fan timer
This will cause the main burner to run untill the over tempreture switch is tripped therefore shuting gas supply and running fan on high till over heat condition is resolved then it will restart burner and repeat
continuing to run heater like this will cause heat exchanger split.
May 13, 2010 | Heating & Cooling
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Mar 12, 2010 | Heating & Cooling
Outside heating unit runs all the time
Feb 19, 2010 | Heating & Cooling
Furnace blowers continues to run after reaching temp
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
Jan 27, 2010 | Electric York / Paragon A-111-20 Heat...
Furnace blower won't stop running
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dayton Gas Furnace Heater Logo
423 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
