Can you help me: how can I see and change the mtu value? (D-Link dsl 2640b)
    President:
  • 1,623 Answers
Why do you want to change the mtu value? That setting will be standardised and auto set on the setup when you connect to your internet provider, kit should only be changed if they have said it needs to be changed. Changing it can result in loss of connection and data errors while connected.
Posted on Apr 10, 2011
I forget admin password model DSL-2640B please help i want change wireless settings .... please help me
To reset the D-Link back to the default settings, press and hold the RESET button on the back of the router and power up the router, hold the RESET button for 5 secs until the LEDs flash at the same time then release the RESET button.
The default login = admin
The default PW = blank (just press Enter)
Oct 11, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I am trying to connect to Xbox Live using a Belkin F7D2301 (Surf Wireless) router and am trying to change the mtu size to 1400. I can't find anyway to do it.
Hi i got your issue I will assit You further......please try with the following steps
Step 1) Connect modem>>Belkin router>>computer
Step 2)Open the browser page
Step 3)Clear everything on the address bar and type http://192.168.2.1
Step 4)Checked towards the left coloumn....under INTERNET WAN click on CONNECTION TYPE-if asking for a password leave it blank and hit SUBMIT
Step 5) Select your connection type as PPPOE and hit NEXT
Step 6) You will get an option to change the MTU SIZE
NOTE: This can be done only if your connection is DSL
Please try with the above steps if you have any issues let me know it
Thanks ......
With regards.....
PRIYA
Sep 02, 2010 | Belkin Wireless Surf Router (F7D2301)
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Needs to know more about MTU size changes
Changing the MTU size to any "small" value is a bad idea -- compare it to running to the corner store every time that you need to take anything (milk, ice-cube) out of your refrigerator -- the "time" to go back-and-forth to the store (or the Internet) will be excessive, and "slow" down your productivity.
Aug 04, 2008 | NetGear DG814 DSL Modem Internet Gateway...
Wireless 108G MIMO Router Model DI-624M
Tell your son to change the MTU settings on the router, especially if you have DSL.
Changing MTU on router
Step 1.
Log into your router by open your Internet browser (e.g. Internet Explorer), enter the IP address of your router (e.g. 192.168.0.1) and press Enter. Specify username (admin) and password to log into the router.
Step 2. Click on the Home tab and click on WAN on the left side.
Step 3. Look for the MTU field (note that it may not be available in some router models). The default MTU value is 1500, change it to lower number, e.g. 1200.
Step 4. Test your ability to connect to those specific sites youre having trouble with. If changing the MTU rate to 1200 does not resolve the problem, start lowering it in increments of ten until the problem is resolved (you may need to go as low as 600 depending on your DSL connection).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 01, 2008 | D-Link DGL-4500 Wireless Router
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
