Model cr 27cd ther eeis a wire on the record player thta i don't know where it comnnects to it is going to the trim pot on the socket board
  • fgoering Apr 12, 2011
    You must not be familiar with this unit. it has a12 volt dc motor fior the drive. it has a plugin board for the motor. the cartridge is working. i need to find out where the second black wire goes on the motor board. it has a 4 leged regulator on it (was bad, i replaced) and tere is a speed swich near by. you have to look at the turntable wiring diagram and find a black wire that comes from a speed adjusting pot and it goes to the regulator area. I hope that you understand now of what i need, maybe you can send me a copy off the circuit. model crosley cf 27 cd, frank
    The regulator number is AN6652. You will need a schematic to tell me where the wire that It need a connection for. The board mounted on the motor has the regulator and 4 holes for wires. It also has a speed pot on it. the 5th wire (black)has no place but it needs to be there.
    President:
  • 1,851 Answers
It's not clear enough to me which cable do you mean. If you have a turntable, there must be a cable with 2 RCA jacks, like this model cr 27cd ther eeis - technical114_43.jpg and one more cable (single pole) with no special connector at the end. If you have a cd player, the only connectors has to be the RCA ones, no extra cable. Please clarify me which case is yours in order to provide you further details.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Apr 10, 2011
  • Stelios
    Stelios Apr 12, 2011
    Sorry for the misunderstanding, I thought that your problem was at the audio output connectors of the turntable. Please give me any details available for the regulator IC (with the 4 leads) in order to help you.
    Waiting clarification, don't hesitate to post.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • Stelios
    Stelios Apr 13, 2011
    Here are some details for the IC:
    Pinout
    TAke a closer look at the typical application circuit. I suggest that the black cable you're talking about is the connection between the Rs potentiometer and the the pin number 2 of the IC. So all you have to do is to connect this cable at the pin #2.
    In case of a problem or clarification or further details needed or a direct link for IC's application details, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, accept my solution.
    Thanks and regards
    Stelios
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
I want to change my own spark plug's
Instructions
    • Locate the spark plug cables along the top or the sides of the engine, depending on CR-V model. Once the engine cools, use the trim panel tool to twist the spark plug wire at the wire's boot, which is the larger rubber portion located on top of the spark plug.
    • 2Pull back on the spark plug wire to remove it from the spark plug.
    • Place the socket on top of the spark plug and turn it counter-clockwise to unscrew and remove the spark plug from the well.
    • 4Rub anti-seize lubricant onto the new spark plug threads and on the tip of the spark plug.
    • 5Insert the new spark plug into the well. Manually turn the plug clockwise to thread the spark plug into place.
    • 6Test the tension on the plug with the tension testing tool. Adjust the tension as needed. Honda CR-V spark plugs generally need a tension between 10 and 15 foot pounds. The spark plug's packaging indicates its suggested tension.
    • 7Replace the spark plug wire, turn it from side to side and lock it into place. Continue the process with the rest of the spark plugs one at a time until all of the spark plugs are replaced.
Jun 24, 2012 | 1999 Honda CR-V
My 89' ford ranger will not pass smog here in socialist california. it has passed for 15 years since i've had it. the new machines indicate that the check engine light is'nt operating. i...
Hi, it's possible the bulb is burned out or not making good contact with the circuit board. It should come on during the bulb check when you first turn the key on. Pull out the cluster and check the bulb. If it's good, see if you can clean the contact surfaces to get it working again. Or, move to another state where they don't worry about stupid things like a light bulb.
REMOVAL & INSTALLATION
See Figures 1, 2, 3, 4, 5 and 6
Fig. Fig. 1: To remove the instrument cluster, first remove the trim panel by removing the lower fascia panel
Fig. Fig. 2: With the lower fascia moved aside, remove the lower trim panel attaching screws ...
Fig. Fig. 3: ... as well as the upper attaching screws
Fig. Fig. 4: Then pull the entire instrument trim panel from the dash board
Fig. Fig. 5: Exploded view of the instrument cluster
Fig. Fig. 6: Rear view of the instrument cluster wire routing and connections
  1. Disconnect the battery ground cable.
  2. Remove the two steering column shroud-to-panel retaining screws and remove the shroud.
  3. Remove the lower instrument panel trim.
  4. Remove the cluster trim cover from the instrument panel by removing the eight screws.
  5. Remove the four instrument cluster to panel retaining screws.
  6. Position the cluster slightly away from the panel for access to the back of the cluster to disconnect the speedometer.
If there is not sufficient access to disengage the speedometer cable from the speedometer, it may be necessary to remove the speedometer cable at the transmission and pull cable through cowl, to allow room to reach the speedometer quick disconnect.
  1. Disconnect the wiring harness connector from the printed circuit, and any bulb-and-socket assemblies from the wiring harness to the cluster assembly and remove the cluster assembly from the instrument panel.
To install:
  1. Apply approximately 1 / 8 in. diameter ball of D7AZ-19A331-A Silicone Dielectric compound or equivalent in the drive hole of the speedometer head.
  2. Position the cluster near its opening in the instrument panel.
  3. Connect the wiring harness connector to the printed circuit, and any bulb-and-socket assemblies from the wiring harness to the cluster assembly.
  4. Position the cluster to the instrument panel and install the four cluster to panel retaining screws.
  5. Install the panel trim covers and the steering column shroud.
  6. Connect the battery ground cable.
  7. Check operation of all gauges, lamps and signals.
Sep 07, 2011 | 1989 Ford Ranger
I have successfully recorded from camcorder on to disc on my Samsung SH893M machine. But can you please tell me how to record from video tape to a dvd disc.
you need to connect your wire to VCR out put and connect the other side to DVD input don't forget yellow to yellow, red to red and white to white if you have 3 prongs wire.
Jun 07, 2011 | Samsung Televison & Video
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
I have Toshiba DVD player/recorder DVR19DTKB2 Problem with timed recording which up to now has worked OK ! I can see the unit recording but when I check the finished result the image is blacked out ie no...
I had a similar problem- check your scart lead is connected firmly.
Also check which socket it is in - not handy if it is in socket 2
and you are recording on AV1.
Hope this is helpful
Pete
Feb 21, 2010 | Televison & Video
Sv400 rev:1.0 motherboard microphone sockets are not working the front socket is disconnected & 5 wires are hanging loose (mic power, mic in, ground, r-out, l-out) the rear microphone socket seems to...
if you look REAL close to your board ther are words that tell you were to plug things in go to the site that the motherboard is made and get a layout of it and it should tell you were to plug the right wires in i do this all the time when i have a problem with my board
Feb 10, 2010 | Computers & Internet
Can my jukebox play stereo
the esm 5.1 is on a lot of nsm models if you need the manual email me at
philhemmings@hotmail.com
i will posta dvd disc with manual and service guide for free on some models there is a switch for mono/stereo
Aug 17, 2009 | Wurlitzer Jukebox CD Player
Wiring diagram for 2055 towbar for honda crv
The best place to connect the wiring is behind the left trim in the boot, there is a grey socket which has all that you need except the fog which can be located in the wiring loom to the left light unit.
Mar 25, 2009 | 2005 Honda CR-V
90 people viewed this question
 Grubhead
Grubhead
