Click here to go to the Official Canon website to download the driver for your Canon IP4500 Printer.
Please do select the appropriate Operating System of your computer to show the compatible printer driver for your computer.
Hope this helps!
If you have a wireless router with a wireless network then -
Configure the IP address your wireless
printer, (this is done through the printer's menu settings) make sure it
matches the IP address range on your wireless network, it maybe 192.168.1.***
then configure the wireless printer with a fixed IP address with the same IP
address range but at a higher address eg. 192.168.1.10 so it does not clash
with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click
Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably
incorrect.
