Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Mac notebook why will desktop not load
  • 37 Answers
IF you selected the BOOT CD option in the options are any other removable bootable media as a boot disk then it will not boot, otherwise your os hdd gone faulty then it will not boot
To resolve for wrong selection of boot disk press option button while u started your system that will show you the booting option there you must to select the OS HDD
Boopathy.T
Posted on Aug 08, 2008
Facebook Issues
You should clean your browser and work scanning device
Mar 18, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac Notebook
Start by doing a system restore, then, if that doesn't work, run a repair with your recovery or operating system disc.
Aug 06, 2008 | Apple MacBook Pro Notebook
How to down load ubuntu linux
Go to the Ubuntu download center
Ubuntu 13 04 Raring Ringtail
And download the 64 bit mac image that works on mac computers
http://releases.ubuntu.com/13.04/ubuntu-13.04-desktop-amd64+mac.iso
Burn it on a CD or on a USB using the instructions on this site
How to create bootable USB stick on OS X
Boot the computer using the image. On Windows based systems you can run a demo (a mock install) to verify compatibility with the hardware. If you are satisfied you may install it alongside Windows (dual boot), or alone. There should be something similar for macs (I know close to nothing on those machines).
Mar 16, 2014 | Apple MacBook Pro Notebook
Once I put in the password the desktop does not
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps.
Thanks!
Regards,
Mactechtrainer
May 06, 2010 | Apple MacBook Mac Notebook
CANNOT LOAD MACBOOK. TAKES FOREVER TO GET PAST THE APPLE LOGO, THEN WON'T EVEN GET TO THE POINT WHERE IT ASKS FOR PASSWORD
Insert your Leopard OS disc and startup your mac while holding down the C key to have it startup using the OS on the disk. When it's loaded, DONT do the install, but go to the desktop menu and launch Disk Utilities and do a disk repair and permissions repair... you should see a good improvement on startup
Nov 30, 2009 | Apple MacBook Mac Notebook
Notebook
Have you tried to boot to the factory disks???? If not try to boot from Disk 1 and press and hold the C button on power up and if you get to the screen that asks for language. If this boots up to that point it appears you have an OS issues and you can do an archieve install which will allow you to keep your old users and settings let me know if you get to this point.
Mac notebook
The most likely cause is a bad hard drive or a corrupted file. Start up the computer in safe mode. (Hold down the shift key while starting) that will force the macbook to run extended tests on the startup drive. If it finds any errors it may be able to correct them. If that fails use the startup disk that came with your laptop and start from it (hold down the C key during start up) that will allow you to use disc utility to try repairing your hard drive.
If the macbook fails to boot to the DVD or into safe mode. Try reseating the RAM chips. Hope some of that helps.
Aug 06, 2008 | Apple MacBook PC Notebook
Notebook
Hi John
Can be because of a couple of things. Normally it is a system error.
If you boot your mac up from your original OS installation disk you might be able to repair the fault with apples disk utility.
Failing that you'll have to re-install the OS.
Aug 06, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook
This is a copy of a previous post of mine -
Fixya - Mac Won't Start
Here are a few things that might help you
Try to start your computerfrom the system CD, if this fails, you may try to start it from theDisk Warrior CD, if this won't work also, I would check the PRAM.
Aug 06, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
54 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
