Question about Keurig B60 Coffee Maker
My keurig is only filling to a half cup - Keurig B60 Coffee Maker
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on May 20, 2011
espressonist
  • 1711 Answers
SOURCE: keurig only brews half a cup
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
  • 4 Answers
SOURCE: Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Posted on Jan 06, 2008
heatman101
  • 43501 Answers
SOURCE: My keurig is not filling up the cup with water,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig does not brew
heatman101
';][-0
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
At first brewer spitout half cup and bottom of cup filled/w grounds,now it starts brewing process but no liquid is released ?
heatman101
Aug 24, 2011 | Keurig B60 Coffee Maker
I select big cup and only fill it half.
heatman101
Aug 13, 2011 | Keurig B100 Coffee Maker
I select a coffee size and the coffee maker will only fill my cup half way and it takes a longer then normal time to fill the cup half way. Help!!!!
heatman101
Jun 16, 2011 | Keurig Platinum B70 Coffee Maker
Sometimes I get a full cup of coffee, other times the cup only fills one half full. Why is that?
heatman101
May 16, 2011 | Keurig B70 Coffee Maker
My cup of coffee all of sudden fills only half way
heatman101
Apr 18, 2011 | Keurig Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
3,608 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
