Question about Braun Syncro 7526 Electric Shaver
SyncroPro 7765 shaver slide is stuck and the shaver wont turn off. Can this be self repaired? Is there another to turn off power? Any repalcement part required?
  • 4 more comments
  • Sid Reynolds Apr 10, 2011
    Sorry, but I can't even get started...
    "After you pry out the blue button."... the blue button is solidly in place.
    Assuming I can somehow remove it, it will be torn off and not be able to be replaced.
    This is because there is no gap between blue button and shaver.
    Also, as I can't turn off shaver, should do any work after the battery has run flat?
    Any suggestions?
    Thanks, Sid
    Repeat of last comment, so no email reply from you.
    Assuming I can probably remove it, it will be torn off and not be able to be replaced.
    Any suggestions?
    Thanks, Sid
    You did answer my previous question, you only seemed to re-answer my 1st question, so I re-ask...
    Any suggestions?
    Thanks, Sid
    sorry, I didn't realise there was comment #2, which I will now read
    I disassembled it, it seemed stuck, so I unstuck it.
    But I've to remove blue power switch because there is a black plug beneath, plus other possible damage which may or may not impact. I've reassembled and at least I can turn it off. I'll recharge overnight, and if it doesn't work, I'll take to Shaver Shop and see what they say.
    Thanks, I'll sign off with you now
    It was helpful in dissembling unit.
    But the unit underneath is complex, and unblocking is a bit tricky.
  • 5,370 Answers
The internal slider which turns the shaver on/off is broken or stuck :--- After you pry out the blue button. In the oval hole where the blue button was fitted you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.But if its not turning off then its broken. When the shaver is turned on with the main On/Off slider, a spring moves a small slider inside to make contact with two areas on the circuit board. The small internal slider is broke in half, so when the main On/Off slider is moved to the off position, only half of the internal slider moves. The other half with the electrical contacts is staying in place on the circuit board, allowing the shaver to still operate.But if its broken then you will have to re-solder this metallic part and it should contact the circuit board to turn on/off.If you are not able to solder it,just get the take the metallic part and shaver to local electronic appliance repair center or at any local tv repair center.They deal will soldering jobs.Just get that metallic part to its exact position.So it functions properly. You can also try pressing the blue piece so that it falls inside, then use a toothpick in the edge and pull the blue piece out with a thin tweezers. --------- If the front blue button is not coming out, then you can get whole front cover replaced.The part is available.Just click the link below:--- http://buyitnow64.stores.yahoo.net/brshparesyho.html ---------------- This should help.Thanks.Helpmech.
Posted on Apr 10, 2011
    President:
  • 1,961 Answers
There is another option to turn off this shaver.. By removing the battery inside.
I do suggest that when you open the back cover of the shaver, instead of removing the battery, you can access the button switch from there. Examine to what causes the stuck up.
Procedure below will guide you.
1. Using a small flat screw driver, remove the top cover by frying it off.
2. Simply remove both side of the shaver after to cover is remove.
3. Unscrew 4 screws holding the back cover.
4. The battery is loaded to the circuit board...the top assembly can be remove easily. This will expose the switch that has been stuck.
Hope you find what causing this stuck up. You may replace the switch if this is broken.
The video from this link will help you explain the dis assembly of the shaver
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
  • Danilo Baraquiel
    Danilo Baraquiel Apr 10, 2011
    no.. please not the color blue button.. I'm talking of removing the top cover to where the top assembly is fitted. below is the image
    Once top assembly removed remove the top cover to where assembly is fitted, see number 2 on the image below
Plasma wont turn on not even the red light
Hello
The power supply board to your tV is faulty. It will be best to repalce the board as card basis, because repair to this board is impossible. the components used in it will be very difficult to get from open electronic spare part market.
2_7_2012_1_36_02_pm.jpgThis is the two views of the power supply to your tV. 2_7_2012_1_36_29_pm.jpg
Feb 07, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
My Braun7570 battery is not able to recharge and I have to repalce the new one. As this modle is old one almost 5 years ago, I start to worry about where I can buy the new battery and how to repalce it by...
You can not use lithium battery in your shaver as the charging system is not compatible. You can purchase compatible batteries for your shaver at shaveroutlet.com. See link below for the item and installation videos
Jul 23, 2011 | Braun Syncro 7570 Electric Shaver
I have a braun 7680. after I was done shaving it would not shut off, It was stuck in the on position and would not slide back to the off position. what is need for repairs.
......it is too messy to full around with switch repair as too many plastic parts etc.
ordered the following from Shaveroutlet for $25 and replace the top assembly....takes less then 10minutes.
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
Jan 13, 2011 | Braun Syncro 7526 Electric Shaver
My TV will not turn on press the power button and nothing also the screen has a rainbow color line on the screen
Ur tv convergence are dead.U must know how to solders?Must repalced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | RCA R52WH73 Projection Television
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Is there any place to send a shaver to be repaired? My trimmer broke. It works but will slide completely out and then have to push it back in.
If you don't want to attempt to undertake the repair yourself, you can contact Electric Shaver Service in Lincoln, Nebraska.
They sell new shavers and replacement parts, as well as provide a repair service for many brands of shavers and clippers. They can repair your Braun shaver for you.
Just go to their web site at www.electricshaver.com and click on the repair service link and fill out the form and follow their instructions for sending in your shaver. Typically, they can do most repairs in about a week from the time they receive it in their shop.
I use them to get repair parts for my shavers and recommend them to family and friends as a good place for parts (and service).
They also sell new shavers too. Hope you find this Very Helpful and best regards!
Sep 16, 2009 | Braun Health & Beauty
Braun shaver 7505.
Greetings,
Need to replace the switch. If you have the skills to disassemble the unit, proceed. Otherwise replacing the shaver will cost you less than having it repaired.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 01, 2008 | Health & Beauty
Repairing electric razor
Questions,
What can be done to eliminate self-starting; slide switches which have become exremely sensitive to the touch and often times turn on when set down after use.
Slide switch covers no longer return to full "off" position. Ive had to use scotch tape to prevent them powering on when placed in suitcase, for example. Is this problem characteristic of Braun razors?
Can a nonprofessional open up casing to administer a very thorough cleaning? And where would one get an instructional schematic? Can one be obtained from Braun?
Thx!! Vince
May 12, 2008 | Health & Beauty
Blue Automatic Lock Button is broken
parts are not available at this time ,accessories are even dropping off
Sep 29, 2006 | Braun Syncro 7505 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
1,077 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
