Question about Whirlpool WTW5300SQ Top Load Washer
Washer shakes and vibrates on spin cycle like it is out of balance.
    Brigadier General:
  • 6,277 Answers
I mostly answer front load problems but ' out of balance' is a common problem with both!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
Good luck,
John C
Posted on Apr 10, 2011
  • 619 Answers
SOURCE: Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Posted on Feb 15, 2008
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
  • 50 Answers
SOURCE: MAYTAG LAT8506AAE WASHER - TERRIBLE NOISE/VIBRATION ON SPIN
Try this for re-setting the balancing mechanism:
With the washer empty, tip tip it forward so that it is just sitting on the front feet. Hold it there for a few seconds, then gently lower the back down. (Often there is a mechanism in the back feet that automatically levels it for you--if this doesn't work, check that the back feet are not damaged.)
Posted on Mar 16, 2009
SOURCE: Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Posted on Feb 16, 2010
heatman101
  • 43501 Answers
SOURCE: Our new GE front load washer shakes/ vibrates and
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Aug 22, 2010
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
Washer balancing load, during spin cycle wasker shakes and walks
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
At end of spin cycle,machine seems to be out of balance. Vibration and noise are severe
1=WASHER MUST BE ON SOLID FLOOR,IF YOU CAN FELL IT SHAKING 2FT OR MORE BACK FROM YOU,YOU HAVE A WEAK FLOOR.
2=BALANCING RING BAD,REPLACE ..
3=MAKE SURE THE TUB IS NOT LOOSE
THANKS LACUZ12
Feb 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washer vibrating badly
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Jul 19, 2009 | LG Washing Machines
During the spin cycle the washer will vibrate and move around. Happens on large and small loads.
Try these
  1. Balance the load
please rate my suggestion
Apr 13, 2009 | Washing Machines
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Whirlpool WTW5300SQ Top Load Washer Logo
278 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
