Question about Performance Teknique (ICBM-5742W) 12" 2000 Watt Dual Voice Coil Subwoofer Car Speaker
Hello I have a icbm-5742 performance teknique with out a box, do i need a seal box or vented box for these subwoufer?
5 Suggested Answers
SOURCE: performance teknique ICBM-5612
Whats yhe Rms on this sub? Which is better compared with the 5712 modle?
Posted on Jun 08, 2009
  • 417 Answers
SOURCE: dont know how to connect daul voice coil on a
If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
Posted on Apr 21, 2010
  • 37 Answers
SOURCE: I need to know if
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Posted on Mar 01, 2011
    Zealot21
    • 83 Answers
    SOURCE: I have 2 kicker cvr
    Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
    Posted on Apr 11, 2011
    I need a user manual for a performance teknique ICBM- 136
    Try Googling (Performance Teknique)(ICBM- 136)(manual) without parens.
    Aug 15, 2017 | Performance Teknique Car Audio & Video
    Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
    I have the same sub on the "digital" amp from the same company.
    I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
    Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
    What is the air ratio for this sub for a custom sealed box
    depends on the shape of the boc but a generalised Cuft for this sized sub and what its rated at is about 2 1/2 Cuft for a ported box and 4-5 Cuft for a sealed box.
    Jun 21, 2010 | Performance Teknique ICBM-5612 Car...
    Hey I just recently buy a performance teknique
    good luck finding one, check ebay, or call Teknique directly.
    Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
    WHAT KIND OF AMP SHOULD I USE ON SOME ICBM-5612
    You can use any type of amp as long it can drive at least 1000 watts and it 2 ohm, 4 ohm or 8 ohm stable.Here is the specs on the woofer:
    • 12" High Performance Subwoofer
    • Rubber Seal Gasket
    • High Temperature 2" 4 Layer Voice Coil
    • Air Vented Aluminum Fomer
    • Dual Voice Coil ( 4 ohm + 4 ohm)
    • Large Foam Edge Surround
    • Bumped Plated For Maximum Excursion
    • Excellent For Sealed and Bandpass Enclosures
    • 70 Oz Magnet Structure
    • 1000 Watts Max
    • Frequency Response: 25Hz-800 Hz
    • 2 Ohm / 4 Ohm/ 8 Ohm Operation
    • Screw Block Terminal
    Also check this website for how to wire it to 2, 4 or 8 ohms: http://www.bcae1.com/spkrmlti.htm
    Dec 26, 2009 | Performance Teknique ICBM-5612 Car...
    What parts are needed for my performance teknique icbm-9500t
    first of one,work start of full effort.in the problem situation no sad.
    Nov 30, 2009 | Performance Teknique ICBM-9500T 7" In-Dash...
    Performance teknique icbm-896 stick on diagnostics
    If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
    Amp in Protect Mode - Troubleshooting
    Let me know if you have any other questions.
    Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
    Performance teknique ICBM-5612
    Mar 22, 2008 | Performance Teknique ICBM-5612 Car...
    Performance Teknique ICBM-774
    It is almost obvious to me that the New Box is Unvented. If you went from Vented to non-Vented. there you go. The Amps and Subs should be doing the same thing. If your Sony 10's are designed for Vented they will not thump right in a NON-vented box.
    Nov 28, 2007 | Performance Teknique ICBM-774 Car Audio...
    Car Audio & Video Logo
    60 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    George Nalley
    Level 1 Expert
    Radames Pagan
    Radames Pagan
    Joe Alexander
    Joe Alexander
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
