Question about Frigidaire Washing Machines
I have a frigidaire front door load washing machine. I was trying to clean the bellows but the inner (circle) spring fall out of the bellows. How do I put it back thanks serial number is BLTF1040D
  • 6 more comments
  • joel_carrier Apr 10, 2011
    the model is BLTF104DS0....I am leaving in Canada I bought the washer in 2005.My problem is to put the spring (piece 7) back in place.
    Thanks
    Just to make sure you get my previous comment.
    The model serial number is the one I gave you. I am leaving in Canada - Quebec. Washer bought in 2005.
    I want to put back the spring ( piece no 7) not sure if the model shown in your link is exactly the same.
    The bellows is still in place.
    Thanks
    So.....
    Rick,
    In my model, I have the oval spring but no retaining ring. or clamp.
    The spring seems to fit by itself in the bellows....
    As you know the spring seems way to small to hold the bellows and I have to work from outside .......
    Sorry for the time zone, I tought you were still there
    Have a Washing machine Frigidaire Front load door. Model BLTF1040DS0 Bought in 2005
    I was washing the bellows and the circular spring fell from the bellows. I want to put back this spring .There is no clamp or ring to hold the spring in place. Seems to fit in one of the groove inside the bellows
    Thanks
    do I need to do that with the bellows in place, or by removing the bellows first
    I am sorry but that doesnt help, Do you have a video showing exactly what I need. Same model
  • joel_carrier Apr 11, 2011
    great effort but it is not the same. Mine has a single coil spring inside the bellows.( not a wire with a small spring. This single spring needs to fit inside the bellows ( in the washing room) on the outer side.....See under my trade mark BLTF1040D
    No use so far, sorry
  • Frigidaire Master
  • 19,396 Answers
Hi.
If you are talking about the circular tub boot spring, then you need to remove the gasket. Pulling out the spring is very easy, refitting is more complicated.
It is held by a clamp or clips, or both (this one has clips as well). Remove it and refit it. To remove the bellow, depending on the model you may need to remove the front panel. I think on this one you need first to remove top and control panel. When you have free access to the gasket, remove the gasket, fit gasket following the tube edge, align the gasket correctly (the soft rubber bellow), then refit the circular spring.
Here diagram, click on the picture to enlarge:
Check also this manual at page 29.The manual is for a similar Electrolux and shows pictures of bellow and spring refit, which is what you need to do.
Regards.
Ginko.
Posted on Apr 11, 2011
  • Frigidaire Master
  • 8,220 Answers
The trick is to have 3 or 4 spring clamps. Start at the top and put the alignment tab in its hole then secure the boot with a clamp. work around slowly and add a clamp at the 3 o'clock and 9 o'clock positions. Just keep at it. Affinity Service Manual
You can go to the Frigidaire tech site technical info section and look at repair videos on how to replace the boot. Go to the site hunt for video training find the laundry tab and choose a video. Uses quicktime player. Password and and all is HERE
Posted on Apr 10, 2011
  • Dan Webster
    Dan Webster Apr 11, 2011
    Typical boot install on a front loader:
  • 1,998 Answers
Ok first thing unless you are overseas recheck that model number this is what i have close to that model number http://www.searspartsdirect.com/partsdirect/part-model/BLTf?pathTaken=modelSearch&prst=0&shdMod=BLTf u can also look through each and see which corresponds to the one you have if you are overseas.Also part number 8 in this diagram is considered the door bellow is that what you are refering to?click this link to see the diagram http://www.fixya.com/PostAnswer.aspx?thid=8908420&ctgid=130&ref=unsl after looking at the diagram here we call that the rubber boot that attaches the inner tub to the outter frame as you can see on this diagram there are two metal rings which in this diagram is part number 7 and part number 49 are the two metal retaining rings that you have. The outter one you would use a screwdriver towards the bottom of where it is seated and pry outward without damaging the rubber boot and then slide the entire ring off the unit this ring has a spring that is located down the bottom of the metal retaining ring that holds both sides of the ring together simply connect both sides and reinstall the ring. If you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations Thanks Rick
p.s on this diagram it shows the spring up the top but i have mainly seen them seated down the bottom up to you top you would see bottom you wont Thanks again
  • 6 more comments
  • Rick Ead
    Rick Ead Apr 10, 2011
    hey joel the spring if still workable simply attaches to both sides of the metal ring if you are unable to attach this to both sides then you would need to order a new retaining ring Thanks Rick
    p.s you have to remove the ring from the unit in order to try to replace the spring on both sides should be easy theres no pressure without the spring on it
  • Rick Ead
    posted answer to this couple minutes ago if you have any further questions message me back and as to the bellows area they are all the same with how they are hooked all have a retaining ring please also realize we are on different times and what ever questions you do have I will answer if I am not on while you are Thanks Rick
  • Rick Ead
    joel look at the link for the part as part number 7 the spring attaches to both sides of part 7 if one of the ends is not hooked then that end has broke off and you would have to buy the ring new Thanks Rick
  • Rick Ead
    hello joel with the bellows in place you can hook and seated into the grooved rubber on the bellows itself you would after you attach the spring on the two points at the bottom of the ring put the top in place first and then slide the ring down evenly until you are able to insert the entire ring there may be a spot that you have to use a screwdriver to put the ring over the lip note also that if the ring had a broken section and you try to bend it to replace the broken section you would actually be makeing the ring smaller and then it would not fit im not looking at the ring that you have unfortunatley so i can only give you advise on how I personally install them any further questions message me back Thanks Rick
  • Rick Ead
    here this should make this alot easier towards the end of this video it shows how to install the ring and the spring http://www.youtube.com/watch?v=k6J1IU2zd... and here is another site as well with how to do the same thing but a different front loader http://www.youtube.com/watch?v=UIVpLlHo1... if you have any further questions message me back Thanks Rick
  • Rick Ead
    Rick Ead Apr 11, 2011
    joel ive seen a video with it as a coil spring but the coil spring is on the inside where it connects to the drum i thought you were hooking the rubber part to the door opening also are you outside of the US reason I ask this is the look ups change from where you are located some overseas models we wouldnt have listed here and I would have to look up for your area Idk why they do it this way they should actually just have one site not frigidaire US frigidaire Canada Frigidaire NZ Frigidaire GB gets confusing but when I originally looked up your unit that model number you gave didnt come up and I used the closest to your model number Thanks Rick
  • Rick Ead
    this is the video with the coiled spring that I was talking about on the frigidaire inside against the tubhttp://www.youtube.com/watch?v=k6J1IU2zd... Thanks Rick
  • Rick Ead
    Rick Ead Apr 13, 2011
    awaiting your reply with how you made out with the video Thanks Rick
Leaking water from inside front
clean the glass inner door @ the bottom. one strand of hair can cause it to leak. if that wont work inspect the bellows (door seal)
Sep 19, 2013 | Hotpoint WMA32 Front Load Washer
I have a foul smell coming from my washer everytime I use it...It almost smells like sewer gas...HELP!!!
you probably just need to clean the bellow. Thats the rubber that goes around the tub and door. f not cleaned, it will get moldy and smelly. Theres a tablet that you can buy called affresh. just put the machine on a regular cycle if it doesn't have a clean or sanitize cycle, and put the tablet in. Let the machine complete the cycle. (without clothes). You can even try wiping the bellow out with vinegar. after each wash i suggest you wipe the machine out, drying the bellow and glass. Leave it open for about half an hour, to let it air out.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
I pulled bellow boot out from door with the bellow clamp
you can try to do it from inside but difficult if you never have done it
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
Changing the bellow on a duet
Tilt the machine back to create more space between the front on the door and the outer drum. Remove the screws for the kickplate and remove the kickplate for easier access. Open the door and remove the spring clamp holding the bellows to the door opening lip. Push the bellows into the drum to get access to the outside/ rear of the bellows (where it connects to the drum). There you will find another clamp which you loosen/ remove with a socket. Some models have an overfill tube on the top of the bellows (remove it from the bellows). At this point you should be able to completely remove the bellows.
Align the new bellows to the outer tub. Attach and tighten the inner clamp (be careful not to over tighten and periodically check the bellows and clamp placement as you're tightening to make sure it doesn't slip off). Attach the overfill tube (if equipped). Lay the machine back to level and install the front of the bellows to the door opening lip. Re-install the spring clamp by starting at the top and working your way down both sides (may be easier with 2 pairs of hands). Be careful not to overstretch the spring on the clamp.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top.
Let me know if you need more assistance.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to change bellows on Kenmore front loading washer
First remove the bottom kick plate at bottom. Then tear off the front of the bellows from around the door. Inside there is a big hose clamp holding the inside if it. Remove completely.
Now,put the inside on first, Tightening the inside clamp. Easy so far, right?
My trick to the outer spring:put a little liquid detergent or soap on out bellow where spring attaches,start at top and work it down and around, use needlenose pliers to help with hard part. Good Luck.
Mar 13, 2009 | Washing Machines
Frigidaire gltf1670a front door seal instalation
Open the door and remove either the outer bellows spring (newer models) or use a putty knife to scrape the glue around the bellows to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
Starting at the top, pull on the bellows firmly (close to the tub) until it comes out of the groove. Once it comes off you will see the bellows spring.
Install the new bellows starting at the top by aligning the marks (arrow on the bellows top and arrow on the tub lip). Work your way around until bellows is properly seated snug against the tub.
Here it gets tricky, it might be easier with an extra pair of hands but there's less room. Some bellows kits contain spacers/plugs which will help to "hold" the spring as you stretch it back in place. Work from the top down on both sides at once. Either use the spacers/plugs or have someone hold the spring in place as you work your way around.
Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet. Either re-install the outer bellows spring or re-glue the bellows to the cabinet. If this is not done you risk a water leak.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leakage. If all is well, make sure machine is still level by try to rock it diagonally from the top (if it rocks, lower the leg that is lifting). Re-install the kickplate and wash some laundry!
Feb 08, 2009 | Frigidaire GLTF1670A Front Load Washer
How to replace the door bellows seal ?
Unfortunately the service manual will not tell you how to replace the bellows.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top. Enjoy clean clothes!
Dec 19, 2008 | Whirlpool GHW9100L Front Load Washer
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
310 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
