Question about Bissell SpotBot Robotic Wet/Dry Vacuum
When plugged in the hose light blinks - Bissell SpotBot Robotic Wet/Dry Vacuum
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Posted on Jul 03, 2011
  • Ashley Willis
    Ashley Willis Dec 05, 2014
    how do you unplug the hose
  • theluvumake Feb 11, 2015
    On the side of the machine you operate the control panel from, you'll see where the hose is connected. It has a release button, hold that down while pulling the hose out. Reinsert firmly and tightly.
@ in one dirt devil light keeps blinking
Hi! The model number you provided M085845 is a corded vacuum that does not need to be charged. If you have a battery operated product, the indicator light will begin to blink after being plugged in for 12-14 hours or more. Try unplugging the charger for a few minutes. Hope this is helpful. If you still have questions please reach back out to us here of Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Thanks!
Oct 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
The red light keeps blinking while I have the charger plugged in, is this normal?
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
Sep 10, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
Why is the indicator light blinking?
Hello! If the charger is plugged in for 12-14 hours or longer the indicator light may begin to blink. Try unplugging if for a few minutes.
Sep 06, 2014 | Dirt Devil M0896RED Quick Power Cordless...
Bag full indicator light on only when I plug the hose back in...
drop a marble or something similar through the hose to see if its clogged
Sep 11, 2009 | Bissell 3522 PowerForce Bagged Upright...
Over heat light
It is one of two problems the hose or attachment's are plugged up some or the motor is getting bad. So check the hose and attachment's if they are not plugged up and it is a motor getting bad.
Feb 23, 2009 | Electrolux Vacuums
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Mar 28, 2008 | Electrolux Guardian Bagged Canister Vacuum
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
462 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
