Question about Microwave Ovens
10oz equals how many cups - Microwave Ovens
  • 17,970 Answers
Check this equivalence...
1 cup = 8 ounces 10 ounces = 1 1/4 cups
Hope helps (remember to rate this answer).
Posted on Apr 10, 2011
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
heatman101
Sep 09, 2011 | Microwave Ovens
Chefmate rice cooker instructions 10 cup
if you put a 10 cups of a rice rinse it first before you add a water , the measure of the water is equivalent of the cup of the rice.now,put 10 cups of water. then put it on the rice cooker, then press rice cooking, it is automatically turn to "keep warm" after it's getting boiled. wait for about 45mins of cooking.thanks.
May 07, 2011 | Microwave Ovens
I have a Henry vacuum cleaner. The nossle that screws into the vacuum cleaner has become loose. Would you advise a website where I can get a new part?
Providing it is not broken, the "cup" end of the black flexi hose can be glued and screwed back on (reverse thread). Equally, if you have the removable type of threaded "nose" on the base, this too can be glued and fitted back in place. Most regular glues will do. For parts, check local directories for Janitorial or cleaning product suppliers, or alternatively contact the manufacturers Numatic who will post you the parts you require.
Dec 20, 2010 | Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Food does not get hot
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 22, 2010 | GE Profile Spacemaker Over-the-Range...
My microwave oven as stoped heating up my food allthough the built in grill and the convection oven are still working normal what as gone wrong and is worth getting fixed or will it be cheaper to buy a new...
put a cup of water in micro and turn on to full power listen for a buzzing noise coming on and off if this noise is not there there is a good chance chance the magnatron has failed and will need replacing which is more likely to be more epensive than a new microwave
Feb 08, 2010 | Microwave Ovens
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
