Question about Cycling
Hello, i have one of these bikes, and need to know what type of tube i need. it came with a flat, and i am trying to find a tube, but not sure what i need. can you tell me what type of stem it has. thank you
    Guru:
  • 347 Answers
The tube has two elements to it, the size and the valve.
The size of the tube will correspond to the size on the tire. Look right on the side of the tire something like 26 x 2.0 or 700c x 23c will be written on the tire. both of these numbers tell you what size tube
The Valve is easier: you either have a Schraeder or a Presta. The Schraeder is the same as on a car the Presta is a thin metal tube with a tip you have to unscrew.
Posted on Apr 10, 2011
I have a Fuji boulevard
the tire size is molded into the side wall of the tire. It will look something like: 26 x 2.125 or 700 x 35c
If the bike does not get a lot of use, you will notice after a few weeks that the tires are soft, this is because butyl rubber tire seep air, just like you car tires do over time. You may have picked up thorn or multiple thorns or glass and this could be imbedded in the tire. The tubes manufacturers spec on new bikes are notoriously thin and very prone to flats. Try replacing your tubes with Thorn Resistant tubes or tubes that have tire sealant in them like Slime Tubes (brand name). Remember to rub your fingers on the inside of the tire before installing a new tube to make sure you have removed the offending thorn, or else you are going to have another flat, sure as shootin'.
May 09, 2013 | Fuji Boulevard FS
I have a Mongoose Maneuver with flat tires. The bike hasn't been ridden in awhile. Do I need new tubes or just need air in the tires? The bike is 14-15 yrs old and has original tubes. Thanks.
If the bike was ridden with flat tires, then go for new tubes. If it was stored outside all that time, then go for new tubes AND tires. If it was out of the sun and not in a hot attic all that time, then just re-inflate. Good luck.
Sep 27, 2012 | Cycling
My airhead viper 2 inner tube has a hole, how do i fix it?
If this is a natural rubber tube,the good old bike patch kit will do.If it is a vinyl tube,there is a type A or type B.(Different chemical makeups in different types of vinyl will only adhere to the same type).I don't know how to tell which type of vinyl is which,so get one of each type(at a sports eqipment store).If the first one doesn't adhere,you should be able to clean it off and try the other kind.
Jun 12, 2012 | Vehicle Parts & Accessories
Hello, recently had a flat tyre on the back wheel of the Vibe, need the tube for inside wheel.. Where can i find these parts in Australia?
Most bike shops should have a tube to fit it but Karlisles in NSW will help www.karlisles.com.au/baby_repairs_spares/instruction_booklets
Nov 12, 2010 | phil & teds Vibe Stroller
Have a flat tire and need to find a replacement
The easiest thing to do is go to a local bike shop ... bring the flat inertube to them... If you can bring it to one of the mom and pop stores usually you get better service and they know alot more than the huge retail stores... ie.. Garts.. Dicks.. Scheels.. etc.. they may even be able to patch it up for you .. hope this helps..I know when I need a replacement if I bring the whole bike in they will even put the new tube on the tire for free,,,
Jan 20, 2010 | Zooper Zydeco Z344 Jogger
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
What size tire tube goes in a 700x28c Denali Bike tire? I installed a schwinn 26inch tube, rode the bike around the block, parked it in the garage and two hours latter, sitting in the garage, the tube blew...
700c tyres are bigger than 26".The tubes you need measure 700x28 (to32).This size is used in Hybrid style bikes.Make sure you get the same type of valve(Schreader are the same as car,Presta are narrower)or it won't fit the hole in your rim.
Make sure when inflating that the tube isn't trapped between the tyre and the rim.Only inflate to the pressure written on the sidewall of the tyre.
Sep 25, 2009 | GMC Denali 700cc Women's Road Bicycle
Back tire changing on mongoose gravity games bike. How do you change the back tire in this bike? It is very hard and confusing. I don't know how to do it. I need help.
If you have pegs on the back you will need a deep socket to fit the nut and a socket extender and a socket wrench. with the wheel off it is just the same as changing any other bike tire. Just make sure you check the inside of the tire carefully for anything poking through that may puncture your new tube. Also check to see if you need a new tire and make sure you inflate the repaired tire to the correct pressure or you may get a pinch flat.
May 11, 2009 | Mongoose Gravity Games BMX Bike
Unusal valve stem on the tire tubes how do I pump?
ok mate you have to go to a bike shop and buy a the newer tubes the one your daughter has is really old and they dont make them any more so just go to a bike shop and ask for a bike tube and then ther you go also if ya need any help putting it on just give us a bell. and dont forget to rate me .
Mar 28, 2009 | Kettler Scoot Training Bike
Flat tire--not fixable--is bubbling
I advise you try the shop where it came from for a replacement tube for it.
Failing that, 'phone the manufacturer to have one sent out.
Jun 11, 2008 | Baby Trend Expedition Double Jogger
Cycling Logo
215 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
