Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way at all to make the engine run faster. thanks, Luke
    President:
  • Craftsman Master
  • 1,545 Answers
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
Posted on Apr 10, 2011
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Removing blade
place a block of wood between the blade and the mower body to hold the blade from turning
Aug 09, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
917.374050 wont start
first check for spark if you do take off the air filter and spray some carb cleaner of starting fluid in the carb and try it if it fires then clean out the carb
Apr 02, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
The lawnmower starts for a few seconds, then dies.
Probably a fuel delivery issue. There is a brass bolt that holds the bowl to the carburetor on. It has an exterior washer, so don't lose. This bolt also is the main jet for the carburetor and can become clogged especially if old gas is allowed to evaporate in mower and no in-line fuel filter is used. Drain the fuel tank (or it will drain when you remove the bowl!). The bolt has very small holes on bottom and sides. Make sure they are clean and clear and the bolt is nice and cleaned up. Use no metal, and/or scraping on bolt. Reassemble (don't forget the carb body gasket) and engine should run if no other issues.
Please vote on this solution.
Sep 04, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Throttle cable is loose from engine; where does it go?
Sears has thousands of illustrated parts breakdowns on their Parts Direct website that can be very helpful in solving this kind of problem. Along with their house-brands, they also have most other major brands available too.
Give it a try:
Sears Parts Direct
Jul 18, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
1,179 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
