Question about Refrigerators
How do I reset the sb 3 max + thermo king unit. sb 3 max has a reset button the + does not. Unit ran out of fuel. now has 1/2 tank and battery is chargfed. Alarm light is flashing. Will not turn on. How to reset ?
    Genius:
  • 1,400 Answers
Hello
Found a usefull link to thrmo king.Shows how to reset alarm.
http://www.thermoking.co.nz/PDFFiles/OperatingTG-VI%20Microprocessor%202005%20CD.pdf
Posted on Apr 10, 2011
Harley troubleshooting
Engine Runs but Misfires
1. Fouled or improperly gapped spark plugs.
2. Damaged spark plug cables.
3. Incorrect ignition timing.
4. Defective ignition components.
5. An obstructed fuel line or fuel shutoff valve
(carbureted models).
6. Obstructed fuel filter.
7. Clogged carburetor jets.
8. Malfunctioning fuel pump (fuel injected models).
9. Loose battery connection.
10. Wiring or connector damage.
11. Water or other contaminates in the fuel.
12. Weak or damaged valve springs.
13. Incorrect camshaft/valve timing.
14. A damaged valve(s).
Jul 11, 2014 | 2002 Harley Davidson FLHRCI Road King...
How to reset computer thermoking semi trailer
I assume you are talking about a thermo king refrigeration unit. I don't know what model you have but there should be two arrow's up and down. Those arrow's should move your set point up or down. If there not working it's possible your company has the key pad locked so the set point cant be changed. Hard to answer this question not knowing what kind of thermo king unit you have.
Nov 29, 2013 | Heating & Cooling
Dropped tank and reinstalled and now not getting fuel to carb. relay,pump,filter...???
sounds like your fuel filter is plugged the fuel pump is finished or you have a plugged fuel return line.
Dec 08, 2011 | 1988 Mitsubishi Mighty Max
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Chevy Venture have O2 error code and out of gas with 1/3 tank
02 sensors read the exhaust fumes and then adjust the car's air/fuel ratio by means of the car's computer. IF the gas guage is off, that would be the sending unit in the gas tank that is sticking
Jul 01, 2009 | 2003 Chevrolet Venture Passanger
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
408 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
