How to change boot order by using cd-rom - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 89 Answers
To change the boot order of a computer, you need to go into the BIOS. To do this, find out the key that you use to enter BIOS, and rapidly press that while your computer is starting up until you're in BIOS. If you can't find out which key to press, or you're too lazy, like me, you can just randomly mash delete and F8-F12 while your computer is starting, since those are 99% of the time the keys used to enter BIOS.
Once you think you're in BIOS (you should be at a blue or black screen with simple text options), just browse around a bit until you find the boot order. Everyone's BIOS is a little different, so just look around a bit, there's not that much to sift through. Some general categories to look for are obviously startup and boot order.
NOTE: Don't worry about messing up your PC by changing around a few options, you can choose whether or not to save the options you just configured before leaving BIOS, and if you DO mess up your PC after saving, you can go into BIOS again and restore the default options.
Posted on Apr 10, 2011
How to change boot up menu to cd rom
when your laptop sets up press F10 that will take you to your BIOS ...next go to "ADVANCED" Next go to BOOT OPTIONS...NEXT go to BOOT ORDER.... To change the order of your boot, use the + and - keys, after you get the cd-rom first in order, hit F10....go over to the "FILE" and save changes and exit. Your laptop will restart on its own ! to change the setting back just reverse the boot order ! :)
Jan 26, 2013 | HP Compaq Presario 2100 Laptop
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
How to make CD Rom run as BOOT? please key in
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device.
If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
Aug 29, 2011 | Dell Inspiron 1525 Notebook
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Will not use the cd rom drive as boot for repair
I suspect you have the boot order in the bios set up to boot off the hard-drive first. You need to change this so the computer will attempt to boot off the CD rom first before it attempts to boot from the hard-drive. I'll try to describe how to do this. While the computer is booting push whatever key it indicates you need to in order to enter setup. Often this is the F2 key. Use the arrows to move up or down the list to an entry that will say something like "boot order". Usually you can select this by hitting enter. Then follow the instructions on the screen to move CD rom to the top of the boot order list. This may involve using the page up and page down keys. Exit and save. This usually involves using the Esc key. Once you set this it will always check the CD rom for a disk before it tries to boot from the hard-drive. It will still boot like normal if it doesn't find a boot CD in the CD rom.
Jun 30, 2009 | Acer Aspire 3004WLCi Notebook
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Computers & Internet Logo
David Payne
David Payne
