Question about Canon Pixma MG5220 InkJet Printer
I have a Pixma MG5220 printer I bought in January. When we try to load the paper, a screen comes up and says No paper. we have hit the OK button as instructed.
  • 128 Answers
There are two paper sources on this unit, One is a cassette tray, a drawer in the lower front. You may have that source chosen, and no paper in it. I recommend using that tray for your regular plain paper.
Posted on May 06, 2011
My Canon printer MG5220 printer says that there is a paper output slot - paper jam
It means one of the sensors did not send a movement of paper, when needed. Could be a sheet of paper, a scrap of paper, but sometimes something just dropped into the printer, like a paper clip. So carefully look (with a torch or other bright light) if you can find anything where the paper should go. also open and close the printer as if you replace cartridges an see if you can find anything that does not belong in a printer.
If you can't find a thing and when you unplugged the printer from the mains for a few seconds. and then switched it on and the error keeps coming back, contact a service centre or buy a new printer.
Jan 13, 2015 | Canon Pixma Mg5220 Wireless All-in-one...
Paper jammed in output slot but not
you might check that the sensor output is not broken. Also see if the sensor does not have a piece of paper.
Apr 13, 2014 | Canon Pixma MG5220 InkJet Printer
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Printer head for my cannon MG5220 wihich was purchased through amazon in December is not working
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 21, 2012 | Canon PIXMA MG5220 Wireless Photo...
How to use the back paper tray for Canon Pixma MG5220 Printer
To use the Rear Tray for your current print job (this should last until you close Word) :
Use Ctrl+P to open the printer window. Click on the Properties button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the OK button.
To permanently set the Rear Tray as the default:
Click the Windows Start button, then click Control Panel and select Printer. In the popup window right click on your printer icon and select Properties. On the General tab, click the Printing Preferences button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the Apply button, then the OK button.
Apr 01, 2012 | Canon Pixma MG5220 InkJet Printer
My canon pixmas paper comes out crinkled every time! What do I do?
You have a small piece of debris stuck in the paper path. Take a good look and try to determine where the debris may be hiding. It's probably a piece of paper left when you had a paper jam.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
The feed switch on my Canon Printer MX700 keeps reverting to the rear tray, so I cannot print out anything on standard 8-1/2 x 11 paper.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Printer paper reloading
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Dec 18, 2008 | Canon Pixma MP450 All-In-One InkJet...
Will not feed paper
There could be a small piece of paper or other matter blocking the feed. Try feeding a piece of thin card- simple load and eject don't try to print anything. Or Put a vacuum nozzle in the slot to suck any debris out. Come back for more advice if this is not the answer.
May 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MG5220 InkJet Printer Logo
419 people viewed this question
old marine
old marine
