Question about Dryers
How do you get the area the buttons are in on a frigidaire affinity dryer open so that you can unstick a button after getting an e68 code i have cleaned around the button and everything but i need to get in to that area? got the top off but need to know how to get in to the rest without breaking something
    President:
  • 3,074 Answers
Unplug the dryer and carefully try to free the button using a needle, do you know which button?? Here is a site:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/137033000.pdf
Hope it helps Tim
Posted on Apr 10, 2011
Need help my affinity dryer has the code E68 on it and the code Dr the model number is LGQ7000ES0
E68 is a stuck button error code... There is a diagnostic video for this on YouTube. You will have to get a new control board to fix the problem because the buttons are part of the board... Frigidaire Dryer Main Control Board 134557200
Jun 08, 2016 | Dryers
Dryer codes
The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Feb 13, 2015 | Frigidaire Dryers
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
I have a frigidaire dryer that it run few minutes and then stop.the scren shows E68 error code. What is the problem and how can I fix it?
E68 is a stuck button check all of the buttons if you can't unstick you will have to replace contol.
Be sure to unplug your dryer before starting any work on it.
You can replace it, just remove the top and then the screws holding the panel, slide to one side and lift out, lay it on a table or on top of the dryer and swap the panel. Good Luck, I hope this helps
Nov 27, 2009 | Frigidaire GLEQ2152ES Electric Dryer
E68 readout on the panel
frigidaire dryers have problems with the computer boards,i've seen the affinity dryer start by itself,it will start to beep and then i can start up,but that error is telling you one of the buttons are stuck,if all the buttons check good you have a bad computer board.hope this helps you out.
Feb 13, 2018 | Frigidaire GLGQ2152ES Gas Dryer
Error code E68
E68 is a stuck button check all button if you can't unstick you will have to replace contol..
Sep 14, 2008 | Frigidaire Dryers
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
115 people viewed this question
Top Dryers Experts
