Question about HP Pavilion dv1000 Notebook
HP Pavilion DV1000 not charging the battery
The laptop works OK, the WinXP icon says it is on mains power, and is charging the battery.
But the battery charge is not going up.
Could there be a fault in the charging circuitry? A 3 year old dv1217 old battery wouldn't hold a charge, so I got the 12 cell 3 - 4 months ago, and now it shows "Charging" but never does or go above 5%. The lightning bolt just comes and goes.
Can this be fixed by itself, does it need a new (rehabbed) mother board, or just go through the easy part of transferring all the data files, and the pain of reloading (and getting approval to do so) to a new laptop?
John
  • chickshepard Sep 01, 2008
    Extended life battery charges to 9%. Occassinally it will show recharged. Is it the motherboard or possibly a battery dying. How can I tell?
  • XionXxen Dec 13, 2008
    I have the same problem. Is there a way to fix without replacing the whole motherboard, it costs about £100.
    Genius:
  • 2,028 Answers
This is going to be a problem with the power management system on the motherboard, it's a common problem. You will have to replace the motherboard in order to fix this. This is a good machine and can be fixed, but if you think it's time for a new one (and can stand the pain) go for it, besides this one will be totally obsolete soon, and you'll probably be ready for a new one within the next two years anyway.
Posted on Aug 06, 2008
    Problem Solver:
  • 16 Answers
Try to change the battery pack or the ac adaptor.
Posted on Dec 15, 2008
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 PC Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
yes its u r mother board battery connector problem...in the mother board there is IC for sensoring DC supply..near the battery connector..plase check the IC is working properly with A logic probe.if it not working plaese replace the IC with a blower..
Jan 19, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
542 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
