Question about Samson R31S Microphone
I purchased a R31S Samson Microphone and it cant be detected when i plug it in to my computer microphone jack. What is it to do?
  • 51 Answers
A dynamic mic connected to the your computer's mic jack is an analog connection. So your computer won't give a notification that there's a mic connected. However, you can view input levels through the default windows mixer of your sound card or any program or application installed on your computer that has the capability. Had it been connected through usb or firewire, it would be digital and you wold be notified that the device had been detected via device drivers etc.
Hope this helps
Posted on Apr 10, 2011
Not working
Is it an electret condenser type then it needs a battery in the shell. The body normally can be screwed open to expose the compartment. Otherwise if it is dynamic make sure it does not need a "Phantom" supply from your mixer. Is it a balanced mic then some of them need a transformer so without seeing it and do tests this is all I can offer
Mar 29, 2014 | Samson R31S Microphone
Microphone will not hook into computer
What is on each end of the microphone cable in its original form? What's the model of microphone? You need a cable that ultimately (probably need an adapter or two) would have the LO-Z (assuming its a low impedence mic) connector for the microphone on one end and the mini phone plug on the other. If the microphone is low impedance, which most good microphones would be, you will need an impedance matching transformer to convert to high impedance which the computer mic input would expect. That would have a 1/4 inch phone plug output which then needs to be brought down in size to fit the computer mic input. A music store would be your best bet for the required pieces.
Jul 23, 2012 | Samson R31S Microphone
Can microphone be used with computer?
Yes, if it's similar to what is pictured above and your computer has a microphone input on it. As long as the computer has the input the most you would need to do is get an adapter for the microphone to get the plug to the correct size. Often times microphones have a 1/4" jack which looks like a larger version of what your standard ipod headphones has. The plug would need 1/8" to work on a standard computer. 1/8" is the size of the standard headphones. Adapters can be purchase from RadioShack for couple dollars.
Hope this was helpful
Ray
Mar 02, 2011 | Samson Dynamic Vocal Microphone
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Samson R31S Microphone
I just today bought a Samson R21S microphone, and I plugged it into my laptop via the laptops microphone jack, and immediately had problems. It cuts off my voice in mid sentence, it wont get half of my...
Not really the mic's fault - just incompatible.
Your Samson mic is a "dynamic" type and the laptop is expecting a "condensor" type.
You could put the mic through a preamp first but easier to exchange for a more suitable type.
Hope this helps.
http://stores.ebay.co.uk/methleykev
http://www.technicsdjuk.com/
Jul 09, 2010 | Samson R21S Microphone
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
What do you hook the microphone up on a stereo in order for it to work? My son says it is the AUX setting?
phones stands for headphone you can use aux input with help of(mic to line converter)from radio shack near you.-insert the converter in aux and insert the mic in converter.
Jul 06, 2008 | Samson R21S Microphone
Samson R31S Microphone Logo
483 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
