Question about Samsung Washing Machines
What does '5e' problem mean? - Samsung Washing Machines
  • Erica Blair
    Erica Blair Apr 12, 2011
    Hi, it was a drainage problem. A small stocking sox was caught in the filter. After I drained the water and removed it, the machine functioned well again. Thanks, it was helpful,
    regards
  • Alfred Mandara Sep 25, 2012
    recently installed a brand new samsung wa85v3 machine. we are getting an error message 5e. we cleaned the magic filter. could it be that the drain pipe level is below the water level in the machine?
  • Samsung Master
  • 1,902 Answers
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Posted on Apr 09, 2011
    I tried what you said but it did not work
My top loader washing machine shows SE. Please assist.
Hi!
I has the same 5E mistake with my Samsung washing mashine.
5E looks like SE on the screen, but it is 5E.
This is what the manual says:
5E - Your washer is not draining. It can
also mean that the unit senses a
small clog while draining
Do the following:
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
Apr 26, 2017 | Washing Machines
I have an LG WM-12230FB and it is showing error code 5E. there is no reference to this code in the manual. Any ideas?? Many Thanks
I believe that when 5e is displayed it means to check the debris filter which is usually located at the bottom right hand side of washer and don't forget to drain the washer first!
Also, is there anything that would suggest the machine is otherwise not running properly?
I would also try to reset it by unplugging it or tripping the circuit breaker.
Let me know if you need more help and I would be glad to assist you further with this.
thank you
Apr 27, 2008 | Washing Machines
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
How do i find 5e?
5e means 5 times e. To get e, enter 1 and then push the "2nd" button and the "LN" button (for e to the power of 1). Once you get e, push the multiply button, the 5 button and then equals.
Sep 22, 2014 | Texas Instruments TI-30XA Calculator
Maytag Microwave MMV4203DB00 HAS A 5E CODE AND IS NOT WORKING AT ALL WHAT CAN I DO?
Hai,you unplugg it for few seconds and reconnect if doesnt clear its a pc board problem which will need atechinician
Sep 12, 2014 | Microwave Ovens
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
Error code 5E
The means the temperature is higher then the set temp. Check the door and set the temp higher
Mar 26, 2013 | Samsung RS2630SH Side by Side Refrigerator
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
I have 5E showing on my dishwasher. What is does this error mean?
ost common error codes that are caused by installation errors are:
  • 5E. If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
  • Info provided by Articlead.com
Dec 09, 2010 | Samsung DMR57LF Builtin Dishwasher
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Washing Machines Logo
289 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
