Question about AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX Mothe... (MB93GBGK8NSL) Motherboard
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
    Sergeant:
  • 236 Answers
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Posted on Apr 10, 2011
Graphic setting
no im afraid the board does not have the slot for the card. if you had one on it it would not matter the size of the mb or gb's of the graphic card that is down to the cards use only not the pc.
Nov 07, 2013 | MSI 845GVM-V (MS-7057-010) Motherboard
Can i run new ati radeon 512mb video memory with 5.0 shader card on acer ACER AST690-U-P925A
1) How much Ram Memory do you have installed? If I have the spec's right, your motherboard's maximum amount of Ram Memory is 2GB.
(PC2-5300 would be best, but the amount is what matters, not the 'speed')
2) What is the Maximum Wattage for your Power Supply?
Takes power for each hardware component in the computer.
Motherboard, Processor, Ram Memory, Harddrive, Optical Drive/s, Graphics Card, etc.
When purchasing a graphics card, this is one of the minimum system requirements you need to know.
Spec's I looked up indicate a 300 Watt power supply.
This is the problem. That, and power supply's Acer uses are low quality.
If you had at least a 400 Watt power supply, you could use this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=41125&Sku=E145-0550
Slap that game around, and make it bark.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
You could also run this if you had the above Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2048679&Sku=M452-7770
[Note*
No. It does not matter if you are using DDR2 Sdram ram memory, and the graphics card has GDDR5 graphics memory.
A graphics card runs independent of the system resources.
(Processor and Ram Memory ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2012 | Acer Aspire T690 (AST690UP820A) PC...
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Secondly;
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Third:
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Works?
Install the other 2GB.
BIOS has to recognize the changes.
Fourth:
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | HP Computers & Internet
Can my mercury motherboard PI945GCM.V1.0 support 4(2+2) gb ddr2 ram
This motherboard will support only Maximum 2GB DDR2 RAMS.
Thanks for using FixYa.
Jun 06, 2011 | Mercury P4VM800M7 Motherboard
I need a list of compatible video cards that can be installed to upgrade the computer to make it run smoother and assist with games, I also need to know what processors can be installed in it ato upgr
I hope you realize the manufacturer recommends a maximum of 1GB of RAM in this system.
Since the system only has PCI slots, any kind of PCI video card should work without a problem.
May 31, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
Aboout ram and graphic card
I can help you with the first part.
Go to http://www.crucial.com/ and run the "Scan My System". It will tell you how much RAM you have, what kind, how many empty slots, and how much it will hold. It will also make suggestions.
It works rather well.
As for the graphic card, not sure what kind of motherboard you have. That is, what kind of slot you have. For gaming, I can tell you that you should get the card that has as much video memory you can afford. If you care to comment back with the model of your motherboard I may be able to help you further.
Nov 22, 2008 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
Computers & Internet Logo
130 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
