Question about Canon EOS 30D Digital Camera with 18-55mm Lens
I have error code #99 on a canon eos 30d - Canon EOS 30D Digital Camera with 18-55mm Lens
  • 747 Answers
Error 99 is Canon's default for several "connection" problems most common are dirty contacts between the lens and camera body. Another is the contacts in the battery compartment both the camera and the battery contacts should be cleaned.
The camera might not be able to read the memory card, download the pictures to your computer and format the memory card don't delete them format the card this function is found in the set up menu.
Formatting is one of the most important functions to keep the camera and memory card communicating AND is the most neglected function. Always format a new memory card and always format a memory card after downloading pictures to a computer. Format a memory card if it's been in another camera.
Cleaning the lens and body contacts can be done fairly easily with a clean pencil eraser, don't use a puffer on the body as you will blow dirt into the camera. With the lens removed hold the camera as much as possible with the lens opening pointed down and gently polish the gold contacts. Do the same with the lens contacts make sure both areas are clean and re install the lens to the body.
Possibly the most important "fix" is to update your camera's firmware. Go to Canon's web site (it can be a bit intimidating at first) and search through until you find the firmware updates for your camera. Download this generally they want you to download to a memory card then place the card into the camera and upload the new firmware updates.
The Canon 30D (in my opinion) is one of the best no frills, greatest working DSLR cameras Canon produced. Not saying the model's beyond are not it's just the 30D isn't loaded down with video functions. Great all around working camera, sorry my rant for the day.
Cheers have fun with your Canon 30D
Posted on Apr 12, 2011
I had the Error 99 Code come and go in my 30D. After doing exhausting research, the code is not for one particular error. From what I found out is it is just a general code that canon produced when there isn't a specific error. I had to eventually send mine in to canon for a repair. The updated the firmware, and cleaned it, but I am not sure what else they did. It hasn't given me a problem since. The repair was approximately 250.00 Good luck!
Posted on Feb 08, 2012
3 Suggested Answers
SOURCE: Canon EOS 30D will not operate
Hey Paul
I have the same problems, I just sent it back to Canon Service Center for repairs. I will see what is the outcome.....
Posted on Jun 12, 2008
  • 80 Answers
SOURCE: error 99 canon 30d slr camera
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked good luck have a nice day!!! :) :) :)
Posted on Apr 08, 2010
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
Jun 17, 2014 | Canon EOS 30D Digital Camera with 18-55mm...
Error 69
Do you mean error 99? An error 69 is not listed in the manual. Error 99 mainly occurs with non-canon lenses, and indicates a communication problem between body and lens. Which still does mean nothing more than: it could be anything... Try cleaning the contacts. Or mounting another lens.
Mar 27, 2014 | Canon Cameras
Error 99 lens shutter
Probably this is caused by a bad shutter
. The 2nd curtain switch breaks off
Apr 25, 2013 | Canon EOS-D30 35mm SLR Camera
The camera was dropped and now wont work but keeps listing error 99
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Dec 12, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
Error 99 appears using 17-85 lens only when some zoom is being used
Can you replicate this fault on other lenses? Is it is only on the 17-85 lens try cleaning the lens contacts with a pencil eraser and see if it helps.
Nov 03, 2010 | Canon EOS 30D / EF-S 17-85mm IS Digital...
Error 99 canon 30d slr camera
err 99 is moisture or dew inside the camera.
May 11, 2009 | Canon EOS 30D Digital Camera with 18-55...
Canon eos30d
Bent/broken card reader pins. Take a flash light and look inside the card reader. There you'll see two rows of pins, 1or 2 will be bent (common problem).
Needs repair service.
Oct 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
I have a Canon EOS 30D camera that I got for chrsitmas and never used. I moved recently and the manual is not in the camera box. Great, I know. But the camera when I turn and try to take a picture is says...
Hi - You can download the manual from the link underlined in blue below:
Canon EOS 30D
For info on fixing error 99 see here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 15, 2008 | Canon Cameras
Error 99 Canon 30D
I also had this problem.
Try to remove the battery for more than 1 minute.
Also try to remove the CF-Card for more than 1 minute.
For me this only resolved the problem for 5-10 pictures.
Then I had to remove battery and CF-Card again.
The only real solution for this problem is to give the lens to repair.
Because this problem is caused by a wrong adjustment of the lens aperture.
Dec 08, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS 30D Digital Camera with 18-55mm Lens Logo
662 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
